Question about Acer Computers & Internet
After installing windows 7, the optical drive stopped working it is not even in the bios
  • 33 Answers
Go to Device Manager
check is cd/dvd show there with proper driver install or with yellow question mark.
if there is a yellow or red sign on it than U need to install a proper driver which U will get it from manufacture site.
Let me know if U need further help.
Posted on Jul 22, 2009
What can I do to reboot new hard drive
So a new drive will of course, have nothing on it at all. Lets just say you are installing windows 7. With the windows 7 disk in the optic drive as the power is turned on - check for boot options at start up or hit your Del key to get in to the bios. Search bios for boot priorities - Set optical CD/DVD drive as primary (first boot) Make sure you can boot to the windows disk.. Once it sees the disk in the drive - follow the directions and the disk with start the install process. AFTER your windows os has loaded, you may need to find orphan drivers that did not load with the windows disk. You'll have to search Dell.com for proper drivers. Oh, huge - If the computer is running SATA 1 - Pentium 4 to first generation Core 2. You may need to hit your F4 key to add other drivers at the very beginning of the windows install.
The drivers most the time, show as a raid driver, but this is needed or your system will never install - The Hard drive will never be found.
Hope this helps.
Have a great night..
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Dec 19, 2014 | Dell Recertified - GX620/2.8/2G/160G/W7P...
Hi I have A Medianpc the system model is a AWRDACPI X86-Based P.C. Do I have to update my bios to install windows 7.If so please could you advise me.
Hey, no you dont need to update BIOS to install Windows 7 but i would recommend doing it anyway. Its always good practice to have latest version of drivers and firmware as they usually fix bugs in existing in older versions as well improve performance.
As for your CDs i would look at the Optical drive you have and perhaps use another computer to copy the Windows 7 to bootable USB drive and use that to install Windows 7.
Hope this helps.
Sep 17, 2014 | Microsoft Windows 7 Ultimate for PC
"asus" laptop boot from bios
Hi.
If you are trying to install Windows 7 from the USB flash drive then you need to configure the drive so the system will see it as a boot drive, see link below for instructions on how to do this. If you have Windows 7 installed on the flash drive then the boot files may have become corrupt thus preventing you from booting into the operating system. Link for installing Win 7 from USB below >>>>>
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
Regards.
Feb 04, 2013 | ASUS Computers & Internet
I have an emachines e442-v634 w/ Windows 7 Home Premium installed. I tried to remove the bottom cover when the machine stopped working with a blue error screen and, I think a cable or wire got...
I would suggest you check the BIOS if everything is detected properly. Like the hard drive and the memory. If both are working properly and being detected by BIOS properly, then you just might need to install your Windows 7 thru USB. You might need to use a different computer to convert your Win 7 OS DVD to USB installer.
1. Use a different computer w/ DVD 2. Use ISO software to convert the Win7 DVD to ISO 3. Download the converter from this link click here or directly from this link 4. Make sure you have an available USB Flash Disk that has a capacity of 4GB or higher. 5. Once you're done converting the Win7 DVD to an ISO file, use the tool above to convert the ISO file into a USB installer.
This will only work if your hard drive is properly detected. Bootmgr error means 2 things, either the hard drive is not detected or corrupted windows installation.
Hope this helps!
Sep 21, 2011 | Computers & Internet
I have massive boot issues...Can't enter BIOS>laptop freezes. Can't load windows in any form safe mode or otherwise. Can't install new copy of windows either freezes or gives a file not...
If you can't even enter the bios, it means you have a hardware failure somewhere, as the bios is independent of the operating system (Windows) and only needs a functional power supply, motherboard, CPU, RAM and of course keyboard to navigate. A hard drive isn't even needed to enter the bios. In fact, it might be a good idea to remove the hard drive and try again to enter the bios, in case the hard drive interface is causing an issue. If you do manage to get into the bios, try to navigate to where you can set the bios back to factory default. If you still can't enter the bios after disconnecting the hard drive, then it's a matter of trial and error, swapping out RAM, the power supply, CPU and removing any other peripherals that may be removable (like a wifi card or DVD drive). If you can't reliably get into and then smoothly navigate the bios, I'm afraid it is unlikely that you'll be able to install and boot Windows.
Nov 13, 2017 | Fujitsu Siemens Amilo M1425
I upgraded matheboard from p6t6 (stopped working for some reazon) to p6t7. My hard drives have been set up to raid. I have windows 7 ultimate installed. I set bios to raid and choose proper disc as boot 1...
On many systems with RAID1 support built into the mobo chipset, that system includes some RAID management software in BIOS. You won't see it until you turn on RAID capabilities in the BIOS and add a drive. But you might find all the details you need in manuals on the matter from Dell, so look for those. They could have come with your machine, or you may have to search their website and download.
On systems I've seen you create and manage RAID arrays using that built-in software, NOT Windows tools. In fact, some RAID1 management tools would allow you to convert a single stand-along HDD to a RAID1 array by adding a matching HDD unit and then having the system copy all the data to the second drive. This is almost the same as the process to repair a damaged RAID1 array by replacing one faulty drive with a new one and rebuilding the array.
HOWEVER, Windows ALWAYS needs a RAID driver installed in it to use any RAID array. If you are simply booting from a "normal" stand-alone disk into Windows and then using a RAID array as a data storage system, the RAID driver installation can be done any time after Windows is running as you set up the new storage system. BUT Windows in ANY version cannot BOOT from a RAID array unless the RAID driver has been installed at the very beginning of the OS installation. This implies that, if you want to convert your single disk into a RAID1 2-disk array and use ONLY that as the HDD resource in the machine, you will need to re-install Windows, this time including the required RAID driver install at the beginning, in order to boot from that array.
I have read that there may be ways to convert a non-bootable RAID array into bootable by some complicated editing of Windows registry and boot files in order to force it to load the right driver at the right time from the right spot on a HDD, etc. But I am not SURE that would work. It's definitely for the adventurous knowledgeable techie.
So here's a quick guide to installing hardware RAID on a motherboard that features a RAID controller. These steps assume you are performing a clean Windows 7 install rather than an upgrade, and they might differ depending on your system set-up, but the general principles should be the same.
  1. Download the RAID drivers for your motherboard from the manufacturer's website and save them to a memory stick.
  2. Back up all your important data!
  3. Turn your PC off and unplug it.
  4. Install 2 hard disks preferably with identically capacity into your PC.
  5. Turn on your PC, press the delete key or F2 key when prompted to get to the BIOS menu.
  6. Find the option to select the RAID mode, save your settings and exit BIOS.image.axd?picture=bios-raid-options.jpg
  7. On reboot you should see a new menu option to enter the RAID controller settings. Enter the key combination when prompted to get to the RAID controller menu. image.axd?picture=amd-raid-menu.jpg
  8. Create a new RAID array selecting either RAID 0, or RAID 1.
  9. Select the disks that will form the array, save the settings and exit.
  10. On reboot press the delete key or F2 key when prompted to get to the BIOS menu.
  11. Check the boot sequence of your PC and ensure your optical drive is top of the list.image.axd?picture=bios-boot-sequence-options.jpg
  12. Insert your Windows 7 disk into the optical drive and exit the BIOS.
  13. On reboot press any key when prompted to boot from the optical drive.
  14. Windows 7 should start installing.
  15. Select your localisation settings and click next.image.axd?picture=localisation.jpg
  16. Click "repair your computer" and click the "load drivers" button.image.axd?picture=windows%207%20repair%20menu.png image.axd?picture=load-drivers-option.jpg
  17. Insert your memory stick and browse to the correct driver and install.
  18. Exit back to the Windows 7 install menu click "Install now" and on the next screen click "Custom (advanced)" to perform a clean install.image.axd?picture=install-windows-custom_thumb.jpg
  19. When you are asked where you want to install Windows 7 you should see that the 2 RAID hard disks are now visible as just 1 drive.
  20. Add a partition to the new drive so Windows with be able to recognise it.
  21. Continue installing Windows as normal.
Dec 04, 2010 | ASUS P6T7 WS Supercomputer Core i7 / Intel...
WINDOWS NOT SHUTTING DOWN COMPLETELY
You will need to enable the Advance power management in Bios and on windows..
Try to see in the bios the advance setting for APM.
Some motherboard you have to enable this.
Other its simply on windows.
After the installation of windows
Go >Right click desktop>properties>then select screen saver tab>below click power>
Then click APM tab
enable and restart
May be this can solve this issues.
Or else I would advice to change the power supply and see.
Regards
uttam
Feb 03, 2010 | Computers & Internet
Repeated failure to load Windows 7 HP
Hi.
Foxconn don't have this board on their list of their Windows 7 supported chipsets (which is hardly surprising), but as you state all your individual components should be perfectly OK with Windows 7 .
I suggest you flash the Bios because Foxconn had to produce a new Bios for Vista in order for that OS to run correctly.
Best of luck.
Jan 31, 2010 | Foxconn P9657AA-8EKRS2H (6938279104065)...
Computers & Internet Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
