Question about Whirlpool DU1055XTSQ Built-in Dishwasher
The dishwasher is practically new. But after it
The dishwasher is practically new. But after it has gone through the clean cycle and I open it up, it is moist inside. Although drying is part of the cycle
  • Whirlpool Master
  • 3,051 Answers
Main support number1-800-253-1301
Email supporthttp://www.whirlpool.com/custserv/email_...
Posted on Jul 22, 2009
Salt holder full of water
Hi Elizabeth
have had a dishwasher for many years and have found this to be a normal practice .... Hope this puts your mind at rest ????
Mar 20, 2016 | Dishwashers
Dishes not cleaning after full cycle running
Your screens are plugged with food residue in the bottom of the unit. clean it out. You can use 1 gallon of white vinegar for your wash after you clean the screens. Start your washer to fill with water but after the water starts, open your door and pore all of the gallon in the unit. Let it now run for 4 minutes and stop it by opening the door. Leave the door slightly open for 1 hour. close the door and let the cycle continue for 4 more minutes. open the door and repeat it a couple of more times. Let it sit all night with the vinegar in it and in the morning - close the door and let the cycle continue to the end. This should help soften and clean out the food particles in the unit. You can repeat the process and get a better cleaning then too. All the scale should be off your dishes now.
Jan 08, 2014 | Frigidaire Professional Series 24 in....
I have a frigidaire dishwasher (1200 series) that is only 2 years old. I is not cleaning well and the motor continues to run even after the wash and dry cycles are done. The motor will stop when the door...
That sounds like a sensor and/or control board issue...
The board has gone wacky and is not running the cycles correctly.
First thing I would do is to get a new board in there and see what happens..
heatman101
Dec 09, 2010 | Frigidaire Dishwashers
Is our dishwasher no good? We have hard H20 and practically rinse clean our dishes, untensils & glasses before we load it. We never use it for pots & pans. There's a sort of soap scum on the...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Nov 28, 2010 | Maytag Dishwasher
Dishwasher not working
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 13, 2010 | Whirlpool 24 in. ADP5740 Free-standing...
Dishwasher is running but dishes aren't clean
sounds like the top or middle spray arm isn't rotating, most likely a clogged spray arm, try and remove sprayer arm and clean it
Aug 22, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Have a brand new maytag dishwasher. When the cycle is finished the clean light stays on and I have to push buttons to clear is this normal?
If you open the door after the cycle, does it clear the display? Mine is a different maytag model, and when it's done it shows the display as clean. The display will go blank when I open the door manually... let me know if that helps.
KEN
May 10, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dishwasher soap not opening
These rely on mechanical timers and springs on the soap dispenser. They get a bit gunked up after a while. Don't prewash and run the the dishwasher for a few cycles with the dispenser open (put the soap tablet in the cutlery basket). If you listen to the machine you may be able to hear the click when the dispenser should open which at least tells you that it should be working
Jun 13, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher
Make sure that you do not open the door during the wash cycle. Wait until all the cycles are complete before opening the door. Especially don't open the door during the drying cycle.
Mar 20, 2008 | Dishwashers
Whirlpool DU1055XTSQ Built-in Dishwasher Logo
107 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
