Question about Mitsubishi WD-73733 73" HDTV
Horizontal squiggly lines
Hey, dcs11173 thanks for your input on my 54 in Mitsubishi projection TV. the model # is WS 55513. sorry it took me so long to get this info. I had to leave town for a wedding. It semms to be getting worse. now I have a lsrge hoizontal line that rolls down my screen along with the squiggly lines. I would appreciate any help or advice you can provide. Thanks in advance. If anyone else has seen this please help also. Thanks
    Top Expert:
  • Mitsubishi Master
  • 75,169 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Posted on Jul 15, 2017
  • 192 Answers
SOURCE: My Mitsubishi VS-60707 Problem...Need Help!
There are two common problems with this set that cause the symptoms you described. Both of them are caused by capacitors: CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03. They are located on the signal PCB. Both capacitors are inexpensive and will more than likely solve your problem. Hope this helps.
Posted on Apr 29, 2007
  • 1694 Answers
SOURCE: mitsubishi WS-55513 won't turn on
Two choices =
1) Replace DM MODULE. 650.00 is right.
2) Rebuild DM MODULE. Done right = a little less than Mits.
Caution: High degree of skill needed and ask about warranty
in either choice.Rebuilds usually cover only parts installed,
not complete module.If you do the research on repair,you
will find pin push reset does not work,in most cases....T.
Posted on Nov 05, 2007
premtech
  • 934 Answers
SOURCE: Mitsubishi ws-55513 green flashing light issue
I would asssume that the four cap replacement you're referring too is in the power supply of the DM module. (The large silver looking box on the left looking at the back of the TV)..
You can unplug that module from the signal board and remove it. Open the cover and you should find 4 16v caps in the power supply. If they look buldged chances are they are the failure. If not you might want to take an ESR meter to them to confirm they're okay and move on... In the back of that module is a small vertical board called the E2P module. Unplug it from the DM and plug the DM back into the signal board. If it powers up your picture might not be in the best alignment but you've identified the problem - just replace the E2P module.
If none of this works you're going to start getting into some greater technical requirements - but let's cover that when you get that far...
Bill
Posted on Dec 28, 2007
  • 1694 Answers
SOURCE: Mitsubishi WS 55513...
www.chrisandnat.com/projects/blinkingtv/blink.htm
Also,check three 4 amp surface mount fuses on trace side
of board.............T.
Posted on Apr 24, 2008
experttv
  • 203 Answers
SOURCE: I got a Mitsubishi WS-55513 55 in
What does the set do when you try to turn it on? What does the led light on the front of the set do?
let me know so i can help
Tim Nolan
Posted on Sep 17, 2008
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Hey anyone there? I have a WS-55513 with a
There are 4 capacitors on the dm board that cause this problem if they are not puffed up, however the dm board will need to be replaced.
Dec 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws-55513
Could be signal board issue,not related to DM.Might be terminal
board problem = less $ and easier to sub than signal PCB.......T.
Apr 15, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi 55" Projection TV / Horizontal Wavy Lines at Start Up
this is very common with these sets. the fix is to replace 11 very very smal capacitor on what is known as the hypermodule. The ideal sitation is to replace the hypermodule. if you can find it. I can do this repair. I have done about 10 at the shop. if you need to i would suggest finding someone who is very experence in surface mounted repair
Mar 18, 2008 | Toshiba 65H81 65" Rear Projection...
WILL NOT TURN ON
Did you say you got it from an X friend? LOL Sorry, its not funny, It obviously didn't like being moved. Sounds like solder problem in the power supply somewhere, hunt round locally for a good shop. (probably a few hundred dollars to get fixed.)
Aug 01, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WD-73733 73" HDTV Logo
170 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
