Ford Master
- Posted on Feb 18, 2017
Re: Where is the body control module located on a 2002...
It's called a GEM - generic electronic module .It is located behind center of the instrument panel .
SECTION 419-10: Multifunction Electronic Modules
2000 Explorer/Mountaineer Workshop Manual
REMOVAL AND INSTALLATION
Procedure revision date: 10/07/2004
Module - Generic Electronic (GEM)/Central Timer (CTM)
Removal
- CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result. Depower the supplemental restraint system (SRS). For additional information, refer to Section 501-20B .
- Remove the audio unit. For additional information, refer to Section 415-01 .
- Remove the center instrument panel finish panel.
- Remove the screws.
- Disconnect the electrical connectors.
- Remove the GEM/CTM.
- Remove the screw.
- Disconnect the four connectors from the GEM/CTM.
