Question about GE (PSS26MSRSS) Side by Side Refrigerator
My 18 cubic feet bottom freezer Profile was making noise like ice was blocking the fan this morning. It was getting quite warm si I unplugged and emptied. This happened about two years ago and it is about 5-6 years old. So I cleaned it after I emptied it and I gave it 8 hours to rest. After a restart it work normally, the temp went down in the fridge and then it stopped and never started again. Is there a reset somewhere? I found in the back a large piece of mastic that was loose over a pipe. Coule it be empty of freon? The last time the reparator came and he tested the gas pressure I guess and maybe he plugged a hole with this?????
  • patryric Jul 22, 2009
    It does not look like he did.
    It's a big chunk of potty that is loose on a tubing and obviously is not doing what it awas supposed to do.
    The model number is PDE18LBPALBS and it does not exist on the internet so far.
    Maybe it's the condenser fan.
    It started then stopped and now the compressor does not run at all.
    It stopped when the temp was half way to a normal fridge temp.
    It started making a bit of noise then stopped.
    As if ice was in the fan.
  • Mike Smith
    Mike Smith May 11, 2010
    Model number necessary . Did the repairman pierce the tubing to check the "gas" ? A good technician can tell the problem of log refrigerant , bad compressor , cap tube seperation , or leak , without piercing the tubing . If he did , refrig is possibly ruined , or call HIM back to recheck . If I come across a fridge with clamp on access valves , I will not work on the fridge . A tech never leaves access valves on due to possible refrigerant leak .
  • GE Master
  • 4,655 Answers
What happend is a sign that the defrost is not happening every 10 hours. Need to examine the defrost element behind the rear panel. Disconnect the power and with one wire on one end of the defrost element removed use an OHM meter to check the defrost heater. On the PSS26MSRSS the defrost is controlled through the mother board so no defrost timers or adaptive defrost are on your model. We do need to locate the problem so I would begin with checking the defrost heater first. Let me know what you find, Thanks, Sea Breeze
Posted on Jul 23, 2009
There is a puddle on the floor in front and under the freezer door. There also is a little bit of ice on the bottom inside the freezer. Also, the bottom produce crisper freezes the produce. Any...
hi,
Your defrost system is the problem.You just switch of the system for 8 hours are more.So the blocked ice in freezer will melt fully and again this type of problem will not occur.
The freezer back side and the evaporator fan and the drain hole is blocked due to frost in the freezer.Once it is solved this problem will not occur.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 14, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Refrigerator temperature is 30. We cannot set it
check the fan that runs between the freezer and fridge in the fan housing is a damper that opens and closes if ice or debris is blocking or in way clear so damper can open and close the fridge is cooled by the freezer
Jul 20, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Ge profile artica constantly knocking
Broken internal motor mounts in compresser.
Jun 03, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Have a S/S GE Profile Artica. We came home tonight to find the freezer not cold enough and the fridge sweating inside. I have done the best i could to clean the condenser unit and the evaporator coil in...
the ice maker quit because the tempt in freezer is too warm / like abofe 15 deg./ the sweating is caused by the ice blocking the air flow . . to correct the problem from comming back ( next week ) you will have to replace the heater or defrost thermo . if these are not bad then replace the main control board .. mm hope thes helped ..
Feb 23, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Ice build up in freezer...Auto Defrost not working Model unknown...smaller model...about 5 feet tall...2 feet wide...freezer on top..no ice maker. Bought in 2002....noise during defrost quit about 2 months...
If it is a magic chef the model number will be on the back of the fridge and will have to order the exact defrost timer for this model. Only place to get will be from repairclinic.com
Jan 31, 2010 | Roper Refrigerators
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My freezer also just jumped to 17° and won't go down to 0.
We need to check the evaporator fan and the condenser fan. The heat in the door frame is normal when the refrigerator runs normally. But when a control board or fan fails the heat may increase because they are heat strips behind the door or condenser lines placed there to prevent moisture around door seals. We also will need to unplug and have a look at the mother board on back behind a panel. Many times the board will show burn marks on the back or front. When you are ready let me know, Thanks, Sea Breeze
Jun 18, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
May 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
172 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
