Question about Blaze Exercise & Fitness
Our Image 19.0 R treadmill just stopped in the middle of my workout. We tried the reset switch and made sure the outlet is working, but it won't start.
    Problem Solver:
  • 5 Answers
Remove power socket from supply outlet,check external fuses or overload reset trips
if still no results open covers and check internal fuses if you think you are competenet to do so otherwise DO NOT IF THINK OF IT.
if a blown fuse is found try to relace with an exact type and value
close back covers and re try
call technical assistance if still no results
Posted on Jul 23, 2009
What could be the problem when the belt stops in the middle of a workout but the computer monitor continues to work?
The safety interlock switch key may have been unplugged it is a red plastic key connected to a string to attach in the event you fall it stops the belt to prevent injuries
Jan 16, 2015 | Exercise & Fitness
My treadmill wont re-boot
follow this steps and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 11, 2013 | Epic A30T Treadmill
My treadmill stopped in the middle of my workout! Power still on. I turned it off and back on. It ran for 2 minutes and then stopped again.
please the video and proceed according. Of course lube the rollers bearing front and back.
God bless you
Sep 23, 2013 | RTO Sole F80 Treadmill
The term immobilize is on the display panel, how do I get rid of that and get it working again
When necessary to immobilize the treadmill, set display to read SELECT A WORKOUT. (Press the STOP Key
twice if not already there). Then hold down the SPEED DOWN Key and press the STOP Key. The treadmill
now displays IMMOBILIZED. In this state, the treadmill cannot be operated. The main motor and incline are
disabled. The treadmill will remain in this state across resets, power cycles, etc. To restore normal operation,
repeat the same key sequence: hold down the SPEED DOWN Key and press the STOP Key. The treadmill will
display SELECT A WORKOUT again.
Apr 11, 2013 | Life Fitness T5-0 Treadmill
Treadmill just stops in the middle of a workout.
Probably is getting overheated.... Also, I have seen some models that stop the workout when the belt is getting too worn out.... Perhaps you should look into replacing the belt. If the screen is losing power too, then it is definitely power failure (in which case, you should examine all the cords and connections.
Feb 28, 2011 | Proform Exercise & Fitness
My NordicTrack EXP 1000 stops in the middle of a workout. Before it stops, I smell a rubber smell. 1) Does the tread need lubrication? 2) Is the motoer burning out?
my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
Jan 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
Life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Feb 28, 2009 | Life Fitness Remanufactured Next...
Exercise & Fitness Logo
188 people viewed this question
Top Blaze Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Blaze Exercise and Fitnes Expert? Answer questions, earn points and help others
