SOURCE: SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
SOURCE: SMEG Oven won't heat up
This is late response but this fault is your fan element. You have two of them, if heating slower than usual, it is only one that has failed. When replacing one, it is recommended the other one be replaced. Tripping the circuit breaker is the symptom. These elements 2100 Watt each are anywhere between $70 to $110.
Service Tech.
SOURCE: Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Please rate my solution.
Thankyou.
SOURCE: Creda Concept Solarglo Cooker. Grill
Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
Testimonial: "Many thanks for the prompt reply. I'll follow up your recommendation!"
Hi Amanda-jayne Kay, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? model number
