LG LST-5100P set top box does not display menu with an older ( 1998) tv set.
Cant select aspect ratios . All I can do is change channels.
Any ideas?
Rod
Comments:
Jul 23, 2009
- Hi Rylee
I was able to get the menu to view on screen by setting the output resolution by using the buttons on front of the STB.
Display Format
Select and arrows to 576i and YPbPr
Menu works fine and I can program etc.
btw at 576p or RGB it did not work.
Cheers
Rodney
Thanks for Using FixYa. If its a 4:3 normal TV or a wide 16:9 TV then you can view high definition picture by using the ARC button on your remote control to change the wide mode(Auto,Letter Box, Pan & Scan). Also check its free user manual for more information.
I have removed the LST box reconnected the TV here at home now, using Cox cable. But I do not have...
(More)
I have removed the LST box reconnected the TV here at home now, using Cox cable. But I do not have the original LG remote. I'm using the NXTV remote that came with the set 2nd hand, the one that WAS being used with it commercially. Will that remote no longer work, specifically for doing the solution sequence of holding down MENU for 10-15 seconds, and then entering the 2-6-6-3 code + ENTER? I tried holding down MENU on the TV, and then after 15 seconds using the NXTV remote but I did not get the next menu to come up as described. Just wondering what I could be doing wrong or if it's the remote. Perhaps I need to buy a universal remote, program it (or order the original remote from LG), and try try again. Suggestions?
Hi i have a DTR-8000 High definition set top box and am trying to set it up on my Samsung LCD TV....
(More)
Hi i have a DTR-8000 High definition set top box and am trying to set it up on my Samsung LCD TV. The channels and sound work fine as the box had been set up on another TV, although i cant get the menu to display on the screen using the remote or on the box itself. So i cant re tune new channels in. Hope u can help
