Caliber Gamo USA Hunter Elite .177  Air Rifle with 39x50 IR Scope Logo
Mark Holding Posted on Feb 18, 2017
Increased power on my .177 Gamo Whisper IGT needed. It is only running at 9.45 ft/lbs. It is 10 months old. Can I return it to Gamo to fix or not. What would the procedure be?
1 Related Answer
mrvetis
Jay Row
  • Posted on Mar 30, 2014
SOURCE: My gamo whisper classic with
Mine has done the same exact thing since the first day I got it really wish id if sent it back before I messed it up so bad trying to get it to stop scope creep?
I can't get my gamo whisper mach with a 3×9 sighted in, I've had it about a year and used several different 177 pellets and still can't get it sighted in.
Ok, set your air rifle in a Vise.
Take a target, look down the barrel of the air rifle and move the target until it is centered on the hole in the barrel.
Adjust the sight until it is centered on the target.
After that the only thing that you need to do is adjust for the range (distance/elevation/vertical setting) of the target.
Regards
Geoff
Jan 08, 2020 • Gamo Optics
Hi, I have a Gamo Pellet Rifle the Maxxim Hornet that has the IGT technowledgy. Does this pistion have to be refilled with gas? How does it work?
It uses the same gas by compressing it for firing, and capturing the gas for repeated use. Most air guns expel the gas with the projectile. This IGT ports the gas back to a reservoir with 99% efficiency. Will it need recharge? That is not clear in the literature. Ask Pyramid Air customer service to verify that.
Dec 26, 2018 • Firearms
Whats is the maximum grain size pellet that can be used for a whisper fusion mach 1 .177 cal
Any commercially available pellet will work. Some styles/weights/manufacturers shoot better in a particular gun than others. Impact points vary with aerodynamics/weight.
I experimented with different pellets to get the most accurate one.
Gamo makes a really good pellet.
Here's a pack with different styles -
GAMO Performance Pellets Combo Pack 177 Cal Multiple Styles 632092854 eBay
Dec 07, 2017 • The Optics
2answers
Why is my Gamo 1250 losing power?
Gamo Big Cat 1250 Problems - Airguns & Guns Forum
www.gatewaytoairguns.org > ... > Gamo & Spanish AirGun Gate
Feb 24, 2013 - 20 posts - ‎8 authors
Gamo Big Cat 1250 Problems, Air guns, Airgun Forum. ... OK, so I bought my first air rifle since being a kid with a crosman 760 and it was a .... but when you get into the 800 and 900 fps range they tend to lose accuracy fast.
gamo lost power Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on gamo lost power related issues. ...My gamo whisper classic with the nitro piston is recoiling hard and is ... IM LOOKING FOR A REPLACEMENT MAINSPRING FOR GAMO BIG CAT 1250.
Big Cat® 1200 Air Rifle ' Gamo USA
Dec 21, 2015 • Gamo Optics
Can i but a new barrel how much
Bone Collector .177 and .22 cal special edition air rifles ...
www.gamousa.com > Air Rifle
The "BONE COLLECTOR" .177 and .22 caliber air rifles. ... blast reducer integrated into a bull barrel, and utilize the advanced IGT (Inert Gas Technology).
images for Bone Collector .177 Caliber barrel
2answers
Where can i find a owners manual. i bought it cheap from a friend but have no manual to it
http://www.airrifleshop.co.uk/Airgun%20manuals.htm
Has some gamo manuals not the specific one you want but has all the important info for safety and operation plus zeroing if its a parts diagram you want look at the following link
http://www.aceros-de-hispania.com/MANUALES-DESPIECES/DESPIECES-CARABINAS-GAMO/despiece-silent-stalker.jpg
1helpful
Can't find the specs in ftbs. my Gamo .177 Bone Collector is rated a 1300ftps. How far can expect to shoot accurately with this break barrel pellet gun?
Depends on who is shooting. But just test your skills on a 75 yard range. Shooting competition, with the special competition guns are shot at 10 meters (about 30 yards) Without a scoop, they easy shoot 80 % of all pellets through one .177 hole on 30 yards.
1helpful
Gamo Hornet schematic
The best thing to do is go on the internet and type in the company name.And see if they have what you need.Or maybe they can tell you who to contact for the schematics and directions to assemble it together.Hope this helps you out.Joseph A Bagli.
2answers
My gamo whisper classic with the nitro piston is recoiling hard and is deforming the opening on the scope stop. I just ordered the plastic bumper stop that Gamo makes but is this normal?
no its not normal,,,check that the piston crown is not braking up as if it was the piston would smack into the breach block causing the hard thump on firing
The magnification adjustment ring on my Gamo Whisper worked fine at first, then was stuck between 3X and 5X. Now it is free again but the scope is not focused on the 3X and 9X settings, but is clear on 5X...
I'm not familiar with the scope, is it an air rifle scope? One stroke type? If not, the backwards recoil of the air rifle is tough on a normal scope, they aren't made for that type of abuse. They work fine with a normal recoil. That is why they started making air rifle scopes. I'm sure that the internals of your scope are damaged somewhat, you can take off the eyepiece no problem, you might find something in there, loose screw, missing screw, you never know, don't get too carried away with the dis-assembly, you'll never get it back together. It sounds like the magnification ring is messing with the focus of the eyepiece. Might just need some oil. Hope this helps.
Top Caliber Optics Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Caliber Optic Expert? Answer questions, earn points and help others
