Question about LG Heat cool Window Air Conditioner
My ac stops after one hour and yellow and green lights are blinking
  • LG Master
  • 3,051 Answers
How to Check Your Air Conditioner Before Calling... [Edit]
Steps:
1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing the life span of your equipment.
2. Wash your condenser coil regularly. Simply turn off your air conditioner, get a garden hose, and spray the coil using an "up/down" pattern. Be particularly attentive if your condenser is close to a dryer vent, or if your neighborhood is full of cottonwood trees. These two items are "air conditioner killers".
3. Look for ice around your condenser. If there is ice around the copper lines, immediately turn off your air conditioner and call for service.
4. Is the condenser and/or furnace operating at all? If not, check breakers and fuses.
Tips:
1. Maintaining your air conditioner and having it serviced regularly increases the efficiency of your unit, reduces energy usage, and prevents wear and tear on your equipment.
2. These instructions need to be modified slightly for window or "through the wall" type units.
Warnings:
1. Do not attempt any repair work unless you are a licensed heating and air conditioning technician. Most states require a licensed heating and air conditioning contractor to perform any repair work.
2. Do not attempt to add or remove refrigerant from your system unless you are licensed by the EPA. Fines and penalties await
those who tamper with or release refrigerant in an unsafe or unapproved fashion.
3. Do not attempt to diagnose any electrical problem unless you have been properly trained and/or are licensed.
4. Do not immediately assume that if your air conditioner is not working that the thermostat is at fault. Tampering with the thermostat
or is related wiring can cause more problems than you initially started with. If nothing is happening with the thermostat set,
mmediately call for service.
5. Do not bend the "fins" on the outside of the condenser. Make certain to wash the coils in an "up/down" fashion.
6. When in doubt, stop. Immediately call a licensed heating and air conditioning contractor. Did you find this Chapter Helpful? Yes No
Edit this chapter
Posted on Jul 22, 2009
BROOKSTONE HDMI PROJECTOR 801143 DOES NOT CHARGE
The Brookstone manual claims it will fully charge after 3-5 hours, but it takes much longer then that. Mine does not indicate green light, but it seems it stops blinking red when its fully charged. After that it run on power directly from the ac-adapter.
If you keep it connected to the AC-adapter after it have stopped blinking red (do not disconnect it at all), it will start to run on the adapter and will not turn off. You will feel the AC-adapter gets hot while its running, something it does not while regular charging.
If it still dont stop blinking red after having it connected to power for 3 days, your AC-adapter is probably faulty. This happened to me, and after allot of research I found this replacement from a US seller on ebay (only five dollars included shipping).
http://www.ebay.com/itm/251623019268?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Good luck with your projector. It a really cool little thing, but it has some design flaws.
Best regards.
Feb 17, 2014 | Brookstone HDMI Pocket Projector
Split system turns off after 35 minutes. Vanes close but operation green light blinks four times. By pressing on/off switch on remote - green light stops blinking. Press on/off switch again, system starts...
Out door compressor getting over heated. Check freon pressure. May be short of gas. If fan motor less rpm, replace capacitor. If condenser dust blocked,m clean it.
Jan 19, 2011 | Heating & Cooling
Recharging - indicator lights when complete
When the green light stays on that means the battery is fully charged. The correct charger for that light is a Class 2 Transformer
Model: KA12D120030042U It has a output of 12VDC at 300 mA
May 29, 2010 | Vector 2M Pwr Rch Spotlight
I turn it on and the green light comes on for a few seconds, then it beeps, a yellow light comes on and then a red blinking light comes on.
Yes this is the YLOD the (Yellow light of death) it happens when the GPU and the CPU overheat and you will need to fix this by stopping the heat build up, you can sned it in and they will fix it for you for $130.
Or you can fix it yourself using a good PS3 Repair guide in under an hour!
Once the heat is stopped it will work.
Feb 16, 2010 | Sony Playstation 3 (PS3) Console
When turning on light goes from green-yellow-blinking red how can i fix
Make sure you use the recommended PS3 Repair guide
Jan 13, 2010 | Sony Playstation 3 (PS3) Console
It's blinking and the light won't stop blinking the it turns off by its self
sorry but its called the yellow light of death..look on youtube or google ylod or yellow light of death solutions...its called this bc when u turn on ps3..the light is green for a moment, then yellow, and finally blinks red...sony charges $150 to fix...google and youtube will show you how to do it....youll need some electronic skills
Nov 07, 2009 | Sony Playstation 3 (PS3) Console
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
Flashing green light prevents printing.
hi!!!!
try to pull out the cardtridge and put it back properly
sometime the cartrigde is place properly on the printer!!!
try to email me ronaldsuboc@gmail.com
Aug 08, 2008 | Canon S520 InkJet Photo Printer
LG Heat cool Window Air Conditioner Logo
271 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
