Question about HP Bestec ATX-1956D 200w HP Part No 0950-4106 (ATX1956D) Power Supply
Want to use the atx-300-12z as a hobby power supply. Need 12vdc.
The supply came from a computer that died. Wasn't very old and the supply did work. I want to use it to power a very small amp in my workshop. I get 3vdc from the green to all the wires on the same side of the 20 pin connector as the green. I am assuming that something got 3vdc on the board to power up the 12vdc output. Can anyone help me?
Barb
  • 721 Answers
You're asking for a fire or just burning out the power supply. But,at your own peril, check the yellow wires for 12v or buy a power supply test adapter from ebay. It bypasses the power switch usually done by the motherboard & will fire up the power supply like it was connected to a board. Then test the wires for 12v. Should be any yellow wire,red is 5v. Green is 3.3 or 3v.
Posted on Jul 22, 2009
Does anyone know who win power are. I am unable to locate them on the internet
Yet another knockoff computer parts manufacturer. They make more of the cheapest stuff in the world. Chang chung people's production ministry of chinesium. Kind of like GPX or HTC. Just buy a new one, a repair is more of a hobby project unless you are a power supply engineer already.
AT and ATX PC computer supplies schematics
Feb 02, 2015 | Computers & Internet
Power supplies
the purple wire.
Oct 08, 2008 | Computers & Internet
What is the value of R61 resistor
It's not worth enough to warrant you risking your life to replace it. Especially on that piece of garbage PSU. You can die if you try fixing a power supply and touch the wrong thing inside. Seriously.
Jun 11, 2012 | SPARKLE Computer Sparkle ATX-300GT 300W P4...
Not sure which plugs go where on the bestec atx300 power supply for gateway computer. remopved the old powere supply, but don't know which plug goes where on the new one.
I'll assume that your old PSU is also an ATX. First, the plug that has a few dozen wires arranged in a rectangle goes into the MB. Your PSU's ATX connector may be split into 2 parts: the AT portion and a square portion with 4 wires. Together, they make an ATX plug. You'll find some tiny plugs with 2-3 wires for your onboard fans. You might find a few slightly larger flat plugs with 4 wires for old floppy drives. The rest should be the regular MOLEX plugs and slim SATA power plugs for your drives.
Aug 15, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
Power supply fan is loud!
Essentially any Standard ATX power supply with a rating of 250 Watts or higher will work
http://www.discountelectronics.com/index.php?l=product_detail&p=1849
Feb 04, 2009 | Dell Dimension 1100 PC Desktop
Missing -5VDC and -12VDC
Could be.Some do some don't.Some have a circuit breaker. Take the cover off and check. Be careful though as some parts in the power supply can hold a pretty significant charge for quite a while even after the power supply is turned off.If there is no fuse or if you change the fuse and it blows again I would say a new power supply is in order. Good luck.
Dec 14, 2008 | Aspire (ATX-AS500W) (atx-as500w 12v) Power...
I have an old e machine 500 (origional operating system was windows 98). I am replacing the ATX switching power supply , 230 wat, model lp6100a. My problem is connecting it. I know all the connectors...
The old AT power supply that these old computers uses has two six pin socket connectors and these are different to the ATX connector.
You cannot buy these power supply now, most likely you might find one/computer in a junk shop.
If you have electronic knowledge you might be able to cut off the connectors from the old power supply and connect it to the ATX power supply and modify the ATX power supply so you can switch on the power to the old computer. The old AT power supply uses a mains power switch whereas the ATX uses low voltage to turn on the power supply.
Good luck & have fun.
Nov 29, 2008 | Powmax 400 Watt ATX Switching Power Supply...
DOA
Sounds like you need a new power supply for your computer.
Jul 19, 2008 | Antec SP450 450W SmartPower ATX 2.0 20/24...
HP 5470c - No power
I've done it, using an adjustable power supply all i needed was 12VDC - 2Amp, the power connector going to the scanner is a 4 pin mini-DIN male, so i've ripped of the cable from the original bad power module, cable has inside 2 wires one black one white and a shielding. Black and schielding are connected together and are going to the minus, the white one is going to +12V
guess what? .... my scanner is working again
Nov 25, 2007 | HP Scanjet 5470c Flatbed Scanner
Computers & Internet Logo
313 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
