Question about Sony DVP-NS50P DVD Player
No color on playback
The sony DVP-NS715P is playing back color DVDs in black and white. How do I adjust to get color?
    Problem Solver:
  • 6 Answers
Try going under setting ans see if you can find anything on color
Posted on Jul 22, 2009
Why is there no color
If using component video out please make sure that all cables are firmly and securely connected to the player and the TV.
-Component = Green/Blue/Red cables or jacks.
If using the video out please make sure that the TV color settings are not set to grey or black and white.
If everything is connected properly I would recommend to connect the player to another TV to see if the same issue will occur. Also check the color settings on the DVD player under picture mode.
Ref: http://www.docs.sony.com/release/DVPSR200P_US_ES.pdf
Dec 18, 2012 | Sony DVP-SR200P DVD Player
Why is it that some dvds only play in black n white?Is there any way to fix this?
Your solution may be to connect your cables to the front of your tv, instead of the back as found here:
http://www.velocityreviews.com/forums/t699272-problem-solved-for-dvds-showing-in-black-and-white.html
Sony also supports this solution, as found here:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C89600&fes=true
Sony also advises it may be due to a faulty cable or if the signal is being transmitted via a vcr.
As per this site:
http://www.gaiaonline.com/forum/computers-technology/sony-dvd-player-only-plays-in-black-and-white/t.41173519/
if your s-video cable going to your tv is loose or is faulty, then only 2 of the 4 pins are communicating with the tv, thus resulting in a black and white picture.
Jun 28, 2010 | Sony DVP-NS51P DVD Player
Our new sony dvd player only plays dvd's in black and white. can't find ntsc button on the remote. need help
almost dvds are recorded in Ntsc & please chang your tv color system so you can see the color because through menu you can olny chang the color system for vcd from your dvd player
Apr 17, 2010 | Sony DVP-NS575P DVD Player
Only black and white
If you are playing different region dvds, they can be of different color formats also
(US = NTSC, Europe = PAL). If your television is not multi-format then non-compatible
DVDs will play black and white. The solution is to purchase a mutli-format TV (accepts
both PAL and NTSC formats)
Aug 31, 2008 | Sony DVP-NS50P DVD Player
Dvd only playing in black and white
Make sure that you connect all of these connections to the right colored cables.
It seems like you only have the green cable connected. Go back and connect the red and blue for both the tv and dvd.
Aug 06, 2008 | Sony DVP-S500D DVD Player
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
Region Code / DVD Player
DVD-player Sony DVP-NS715P r1/r3/r2-Japan don,t have solderless upgrade
(Example: PDA, DESKTOP, IRC, CD-R and etc....) in
variant MULTIREGION, and NTSC and PAL-enable, and Macrovision OFF.
The modification of this player is done only through special
Sony-Data-service-cable and special firm software through plugs
On main-board (plug CN-103) and on IR-board (plug CN-405).
Mar 19, 2008 | Televison & Video
if you are using S-video cables for your video, try replacing the cable. svideo has 2 lines in it, one for color (chroma) and another for brightness (or black and white-ness (lumina) if one of those little pins is broke, or missing, or the cable is bad, this may be the case.
Aug 13, 2007 | Sony DVP-C660
Sony DVP-NS50P DVD Player Logo
283 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
