Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon D80 won't take photos!
When my Nikon D80 is turned on it will not take a picture on auto (and often not with the other features either). When you press the button the F indicator flashes F - - How do I resolve this?
  • 146 Answers
The F-- error means that the camera does not think that you have a later AF type lens attached.
If you are using the 18-135mm then the camera is not properly connecting to the lens.
To test this, press the lens release button on the camera and slightly turn the lens as if you are going to release it then turn it back to lock.
This may fix the problem.
If not you can try remounting the lens a few times and if that doesn't work you could clean the lens contacts.
The contacts are the metal studs on the back end of the lens, the bit that goes into the camera.
Sorry if that is too obvious.
If you have an early lens it must be set to the smallest aperture using the ring around the lens.
This will be 22 or 32.
Then lock it using the little lock near the ring.
Posted on Jul 23, 2009
How can I turn on my Playback Menu for Nikon D80?
Nikon D80 - Revealing the Hidden Menus - YouTube
? 3:11
https://www.youtube.com/watch?v=IEJ1nuPCl_c
May 7, 2008 - Uploaded by LarkPhoto
By default the D80 hides several of the more technical menus so that ... you activate either the 'Full' or 'My menu' option from thesetup menu.
Nov 26, 2015 | Nikon D80 Digital Camera with 18-200mm...
I have a Nikon D80 camera. I somehow, unintentionally turned on the preview screen that shows all of the info. I don't want any print on my screen, no highlight, no RGB, nothing but picture.
If you were seeing a preview on the LCD monitor on the back of the camera, then there was something seriously wrong with the camera. Nikon did not introduce the LiveView feature until later models.
If you're asking about review instead of preview and seeing graphs or lots of data, press up/down on the multiselector to cycle through different views of your pictures until you get to one you like.
Nov 19, 2011 | Nikon D80 Digital Camera
Nikon d80 will not take a picture the letter r flashes
your subject maybe very near that's why the auto mode prevents you from closing the shutter. R just stands for remaining images in the buffer.
Dec 28, 2009 | Nikon D80 Digital Camera with 18-135mm...
My D80 will not auto focus with any of my 3 Nikkor lenses. It will fire on auto focus when you manually focus while in that auto focus mode.
Press the AF button on the top of the camera (to the right of the window) to select an AF mode & make sure the M/A (Manual / Auto focus) switch on the lens set to "A"
More info below:
http://www.kenrockwell.com/nikon/d80/af-settings.htm
Oct 05, 2009 | Nikon D80 Digital Camera with 18-135mm...
When my camera is turned on it will not take a picture on auto. When you press the button the F indicator flashes F - - How do I resolve this? I am on vacation and my handbook is at home.
What lens are you using? If it is a G series, then this is a Nikon repair...if the lens has a proper aperture ring check your lens is on AUTO not an actual aperture....
Jul 08, 2009 | Nikon D80 Digital Camera with 18-135mm...
Shutter not responding!
i had a similar problem - it was the interface between the lens and camera - some of the connectors were stuck depressed, i just poked them and they popped back out.
May 05, 2009 | Nikon D80 Digital Camera
Can't turn off/disable optimize image screen- nikon d80
Ok, all you need to do is:
1.Hold the camera normally like you would take a picture.
2.Turn it on and review a picture.
3. While looking at a picture, take your index (pointer) finger and rotate the front "wheel" right under the shutter release button. This switches the viewing mode, and should solve your problem.
Jan 12, 2009 | Nikon D80 Digital Camera with 18-135mm...
Looks focused but isn't
Try this.
Switch D80 on.
Reset the camera by pressing the two buttons with a green dot beneath them on the top of the D80, right hand side.
The buttons are AF and +-.
These must be pressed together at the same time for a few seconds.
This is just in case you have set something strange, you do not need to do this all the time.
Set the command dial to Auto.
Set the button on the lower front/left hand side to AF.
Set the lens to A.
Now you can just take pictures, the D80 will autofocus and set the exposure itself.
Jan 01, 2009 | Nikon D80 Body Only Digital Camera
Dark Picture
I am assuming the following two things.
1. The part was indoors.
2. You are using the 18-135 mm lens with the Nikon D80.
The problem with shooting indoors is that not enough light goes in through the lens to the filter. Solutions:
1. Use the flash with every shot. In case there is not flashlight available, use the on board flash. Press the top button behind the barrel on the camera. It has a lighting icon. It will pop open the flash. If you are in 'P', 'A', 'S' mode, the camera will sync the shutter speed with flash. If the camera is on auto mode (The green camera icon) the flash will pop up and fire by itself.
2. Use the lens with with lowest f stop, i.e. with bigger aperture.
3. Increase ISO. You ought to get usable photographs right up to 800. To change ISO, press the button on the back of the camera which says 'ISO' (Second button from bottom) and turn the primary command dial simultaneously to change ISO setting. Higher ISO speed = Lower shutter speed (But less clarity too).
Hope it helps.
Satdeep
Jun 15, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80
Hi taylorrm, I don't know if you have a solution to this but sometimes the AE-L/AF-L but gets pushed which is the auto focus lock button then the shutter release button cannot be used to focus and yu have to reset by pressing it again.  Even though it's confusing at first it's a feature along with the AE/AF Lock to try out to lock your focal area on a subject prior to shooting.
To sbhoward5, check to make sure the switch on the camera body is switched to AF instead of M mode(looking at the front it's on the lower right hand side below the lens release button), which sometimes happens when changing the lens - so then the mode selected is in P,S,A, or M modes on the mode dial. happy shooting,
randy320sgi
Jun 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
1,831 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
