Picture quality terrible/ too much red/ letters have red shadow / ran diagnostic test all stated 0/ adjusted red voltage didn't eliminate red shadow just made less visible/ sony rear projection model: KP-53HS30 year 2002
  • 13,433 Answers
That sounds like a convergence IC issue, have a look at this page.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Does it look like this?
picture quality terrible/ too much - 7be4eec.jpg
I would recommend you get your hands a service manual and replace the Ic's the page linked above has instructions.
You can look for service manual / documentation from
http://www.manualsparadise.com
or http://servicemanuals.net/
You can look for the parts at
http://www.electronix.com/
or http://www.partstore.com/Model/Sony/Sony/kp53hs30.aspx
Posted on Jul 22, 2009
Thanks kumar of recent i discovered that on booting the picture is faint and over shadowed by white light but you can still see the post and windows i now ran diagnostic and it gave me an error code...
go to website from your supplier monitor, and RUN the diagnostic from them, and test it. Otherwise, get the support from them via ONLINE chat.
God bless you
Oct 23, 2013 | Computers & Internet
How do I adjust the manual convergence? I am in the settings, but my TV is not letting me adjust anything. I chose the "reset to factory" choice, but that didn't fix the red/green shadows
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 27, 2011 | Philips Magnavox 51MP392H Rear Projection...
Picture quality terrible on Microsoft LifeCam VX-1000 Webcam
You should be able to adjust the focus by adjusting the lens.The little housing where the lens is should be able spin a bit. If you gently spin it a bit, it should change the sharpness of the image on the screen.
I hope this help you.
Oct 14, 2009 | Microsoft LifeCam VX-1000 Webcam
RCA D52W23 convergence problem
If you cannot adjust it with customer menu u need professional. May need service adjustments.
Apr 08, 2009 | RCA D52W23 52" HDTV CRT TV
Color shadows
Good Day, beekae;
No, there no other adjustments that can be made, the TV has had a Convergence Circuit Failure. The "CCF" is caused by that circuit, please call an Authorized Service Center and get an estimate. The avg cost is about $550.00. Good Luck, big IRISH.
PS or come back and I'll tell how to fix, if you are handy and own a good soldering station.
Aug 26, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Just bought 42" Aquos but has bad picture quality in Analog & Digital cable
There is no secret to adjusting the picture settings on this unit. My unit is perfect with Hi Def signal and better with Blu Ray. I assume you are using HDMI cables and have tried a new HDMI cable to eliminate the possibility of a bad cable. If you have done this then the unit has a problem and I would take it back or contact Sharp to get an auth. service center involved.
Jan 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Red shadow
bad connections on the converganc ics just solder them this will fix the problem if not replace them
Nov 03, 2007 | Sony KP-46WT500 46" Rear Projection...
Screen Voltage
is the black box about 3inx3in insize and can you letters on it and may the words focus or screen if so thats it the pots are counter sunk and must be adjusted with an insulated screw driver ,if your not sure get a tech to do it for you.
Aug 26, 2007 | Samsung HCN4226W 42" Rear Projection...
Red Shadow on scheen
your tv needs to be align take it to a tech so that the tv can get a convergence adjustment it is call color bleeding.these things when a set gets old this wil cost between 440.00 TO $75.00,in this the comb filter and the screen voltage will be checked.
Mar 29, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Its a slight possibility that a 2.00 Part called a capacitor could be bad on the screen drive voltage source. But most likly it sounds like the Picture tubes are comming to the end of there life expectancy. If the crts are weak there is a crt rejuvinator that could possibly clean the grids off each color gun. But this is a crap shoot, as sometimes it destroys the tubes. These type of repairs are not for the handi-man or a consumer to do. There are no real user replaceable parts inside so unless your able to solder and know the HI Voltage saftey issues, you should call a pro to assist you in this repair. Good Luck
Jun 24, 2006 | Philips 9P6031C 60" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
