Question about Freezers
Ice maker is not making ice. I can see no other problem and as far as I know the freezer was not left open as there is no frost buildup inside the unit. Everything is frozen, only problem is NO ICE!!
  • Freezers Master
  • 1,606 Answers
Pour about 1/2 cup of water into icemaker and see if it dumps the cubes after a few hours . If it does , and icemaker does not refill , then water valve is the problem . If the icemaker never dumps the water poured in , then icemaker is bad . ALSO , check to make sure the coils under refrig are clean of dust , lint , etc . Icemaker has to be 5 degrees to operate .
Posted on Jul 22, 2009
2 Suggested Answers
  • 523 Answers
SOURCE: Ice buildup inside floor of freezer (no frost model) Kelvinator N
the drain is clogged
Posted on May 05, 2010
Our ice machine is making too much ice. When we open the door, ice spills out - so for some reason, whatever triggers the machine to know that it has enough ice made, seems to be malfunctioning. Any...
When frost builds up on the little flapper at the top of the door above the ice maker it can get stuck. It tells the ice maker to keep making ice. Try cleaning the mechanism of frost and make sure it operates freely.
Oct 17, 2013 | Electrolux Stainless Steel Under-counter...
Freezer compressor gets hot
Check behind and underneath for dust buildup, sounds like your compressor needs cleaned on the outside, the dust is causing it to overheat and retain condensation, hence the ice buildup. Easy thing to check, good luck.
Jul 02, 2017 | Frigidaire 19.53 cu. ft. Commercial...
Ice maker icing up
Sounds like you may have a couple of problems here. The frost build up could be from a bad door seal. Moist air can be drawn in and collect on the inside. As for the water temp, it sounds like the water line connected to the refrigerator could be tapped off a hot water line. It needs to be connected to a potible cold water line.
Aug 26, 2009 | Kenmore Freezers
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Jul 13, 2009 | Amana 19.6 cu. ft. / 555 liter Upright...
Frig no longer cold
Hi, look inside freezer and see if there is a frost build up on the rear wall. Also listen to see if the evapotator fan motor is running.
Please let me know so I can assist you further.
Vic
May 27, 2009 | Frigidaire Freezer Refrigeration White...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frost buildup in frost free freezer
There is a defroster built into the ice maker to melt the ice a little around the edges before dispensing on most ice makers it may need replacing.
Jul 28, 2008 | Freezers
Freezers Logo
298 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
