Question about SanDisk Sansa m200 SDMX3-512 MP3 Player
Not enough room for music database please free 4 mb
How come when i try to listen to the music on my mp3 player it says "not enough room for music database. please free 4 mb" Then when i try to delete 4 mb i can't cause when i try to it shows that there is no music on my player, exept the basic stuff. PS. when i try to sinc music to it , it cuts off before i can finish. please help. When I try to go to Sansa website to get updates, my computer says the site is not recommended. So now what? The mp3 is dead!!!
  • 626 Answers
The device needs at least 4MB of free space.
You need to keep deleting files until there is 4MB less than the total capacity of the device.
Its not syncing because the device is too full.
If removing the 4MB doesnt work. Try formatting the device thru My Computer>Device Name (m200)>Right Click and select FORMAT.
Best of Luck.
Please RATE my solution BELOW.
Posted on Nov 20, 2007
How do I delete 30mbs from my sansa clip the message is: not enough space for music DB. Please free 30mbs
The player needs free memory to build its database for playlists to playback.
To free memory on your player:
1. Connect to a computer
2. Save a backup of (preferred all) songs to a location on the computer
3. Delete some files off the player to free at least 30 MB memory in the Sansa Clip
Use the manual for how to connect and delete music files.
Clip manual:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
Need more help ? Just add a comment in this thread.
May 21, 2010 | SanDisk Sansa Clip MP3 Player
" Not enough space for music DB. Please free 8 MB." Huh??
wire it up to a windows pc, treat it like a harddisk, search through the folders for the mp3's you won't to get rid off,delete the files you want from it, like you would from a computer.then copy some mp3's
to it, unplug, finished.
formatting it might erase some of the software the player needs to run, so you better don't. enjoy your favorite music :-)
Jul 22, 2009 | SanDisk Sansa E280 MP3 Player
Not enough space for music db. Please free 6 MB.
If you have formatted there is no music on the player. You will have to re-sync any the music. Set the USB mode to MTP, then Use Windows Media Player 10 or higher to sync player.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 03, 2009 | SanDisk Sansa e260 MP3 Player
My mp3 player doesn't player
If you are using the Sony Sonic Stage software, then it might be
a good idea to just format the MP3 player and start over downloading music to it. You have to use the Sony Sonic Stage software or else it gives you the NO DATA BASE error, even if
you have music on it.
Jul 31, 2008 | Sony NW-E002 MP3 Player
MP3 needs to refresh DataBase?
You have to many songs a sansa e 250 only holds a certain amount of space so your best bet is to buy a memory card or delete songs so you can add new ones.
sincerely,Britani
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
Your device has too much music on it.
You need at least 8MB free in order for it to build the "database".
Connect the device to your computer, delete 10 songs, then re-start the player and you should be back to normal.
Best of Luck.
Oct 12, 2007 | SanDisk Sansa m230 MP3 Player
'no database'
The Database error is generally because the device does not have enough free space to create the database ( or GUI ). Delete some songs off the device and that should solve it. You should generally keep 6MB free for every 2 gigs of music. Please add to the question for additional assistance. Best of Luck.
Oct 02, 2007 | Sony NW-E002 MP3 Player
I need help with my Sansa Sandisk e250R
To fix it, format your Sansa. I had the exact problem. Plug it in, then in "My Computer" right click its icon and hit format. Do not select quick format. Then it will be fixed.
Apr 27, 2007 | SanDisk Sansa e250 MP3 Player
format and then update the firmware of the player. 1. Open "My Computer." 2. With the player plugged into the USB port, right-click on the player (if in MTP mode) or the drive letter for your player (if in MSC mode) and select "Format" from the right-click menu. 3. Press "Start." 4. You will receive a warning that the format process will erase all data on your device. IMPORTANT: Make sure you have backed up all of your data from the device before continuing with the format. Agree to the warning. 5. The format will complete. Close the format window and your player should be ready to use. After the format, let us install the latest firmware update for your player. Please visit the following link to download and upload the Firmware on your Sansa m200: http://www.sandisk.com/Assets/File/Downloads/firmware/sdmx3-iv001.exe PLEASE NOTE: All files will be deleted. Backup your files. Your MP3 player must be in MSC mode before installing the Firmware update. To set your player in MSC mode, let us do the following: 1. When the player is turned on, press the ?Menu? button. 2. Navigate to the ?Settings? menu. 3. Navigate to ?USB?. 4. Under the ?USB? menu, switch from ?Auto Detect? to ?MSC?. After changing the player to MSC mode, reconnect it to your computer. The screen on the MP3 player should read ?USB Connected? and ?MSC.?
Jul 04, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m200 SDMX3-512 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
