Question about Jura Capresso Impressa E8 Espresso/Coffee Maker
Error code 8 on machine, will not allow me to put in drawer
I have an E8 and got the Error 8 code this morning.
I turned off and unplugged the unit.
Took out the drawer and cleaned out the grounds, washed the base.
Took a towel and reached in and cleaned out what I could.
Took my vacuum and cleaned out the bottom and out through the grounds hole in the top.
Then I plugged in the machine.
Turned on the machine.
It complained that the drawer was missing (because it wasn't in all the way).
I pushed the drawer in, holding it in place with my thumbs to the proper depth, and hit the coffee button.
It made the espresso, and, having made that cup, the workings got into the proper position and now it's working just fine.
I don't know why it got out of wack. It may be that there's something internal that needs replacing, but I am loathe to be separated from my machine for the time it will take to repair, so I'm glad that it's back to normal now.
BTW, I couldn't find the capresso - any model - on the appliancepartspros.com site.
Posted on Jul 26, 2009
    Scholar:
  • 42 Answers
Tjhe place you want to go is this website "appliancepartspros.com" enter your model number and they have complete picture breakdowns, how to instructions, and parts. Join the their blog and you can post questions that an expert in the field will send you a raply to. They do have basic troubleshooting info on the website as well. iIam sure the website will be able to help you.
Posted on Jul 22, 2009
MACHINE FLASHING DDO CODE
Hi Friend, this is Z. Thank you for allowing me to assist you!
Generally, error code DDO means that the dispenser drawer on your unit may be open. If so, close the drawer and the error code should resolve itself.
If you've double-checked the drawer and it is closed, remove the drawer and examine the magnet. If the magnet is missing or defective, the magnet probably needs replacing.
If the magnet is fine and in place, an experienced technician may need to examine the reed switch or main control board.
Since there are cost differences in parts and accessories, it is always a good idea to have a service tech properly diagnose your appliance.
Jul 12, 2014 | Electrolux EW1200i Front Load Washer /...
Dishwasher initially not draining came up with another error code, however now after fiddling F1 code which says online wet service panel and to take out draws... We can't work out how the drawers com
At the end of the rails which the drawers slide in and out on should have some sort of pin that can be removed which would allow the drawers to slide all of the way out. Just be sure not to damage the pins/clips when removing so that they can be used again when putting the drawers back in.
Oct 01, 2012 | Dishwashers
Hello, We have an F1 error code on our F&P dish drawer , having now completed the checks as per this online video http://www.youtube.com/watch?v=UXzuJvKIIgU, its seems the actuator motors are no longer...
Hello
This is an internal flood error code,Drain as much water as you can out of the machine by tipping machine forward and allowing water to tip out of base
Sep 10, 2011 | Dishwashers
Gaggia Digital Syncrony dredge drawer error won't
Hi
Do you still have the tab on the left side of the dredge drawer? If you do, you can loosen the 2 screw just above the slot wherer you put the credit card. Push down on the plastic ramp in the slot as far as you can, then holding the ramp down tighten the 2 screws. If you don't have the tab you will need a new dredge drawer. Also on some machines the drip tray will lift the dredge drawer and it will give this message. There is a extra piece of plastic in the 90 deg. notch that can be trimed out to stop it from lifting the dredge drawer.
May 14, 2011 | Gaggia Syncrony Compact Digital Espresso...
Lower drawer F1 error code, I suspect possible seal leak. Very small amount of water on floor. Upper washer control panel cycles rapidly through all programs and back light is burned out. I suspect control...
Yes this means that the machine is detecting water under the bottom drawer. Pull the bottom drawer out and soak up the water with a towel and then the error will go away. This happens often because something gets put in the drawer that's too tall and doesn't allow the lid to come down all the way and seal.
May 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Ddo
Hi
This ddo error code means Dispenser Drawer Open.Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing. The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself, you will see snapping clips to unsnap, then you will see the magnet#8 in diagram#1 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=117979
reference
http://www.fixya.com/support/t2180388-code_ddo
Mar 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
Dishwasher beeps constantly and gives fault code that the flood switch has been activated. Neither drawer will trun off. It seems the fan keeps going, and is very noisy. It worked fine last night.
Hello there:
here is some ideas that will help you clean off the flood switch thatis causing the error
first unplug the power going to the machine
If you by accident overloaded the top drawer and this will allow water to get into the base an trigger the flood switch. which causes the error that you get .
Take the bottom drawer cover off first then took the whole drawer out and gently manuevere it to where u can get into the bottom of the unit.
use a towel and dry up any visible water.
use few paper towels to get into and under tight spaces.
now Take a blow dryer and blow the in the base for about 10 minutes. once there is No visible signs of water any where
put it back together and it should work . ok
Hope this is very helpful for you
Best regards MIchael
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Code ddo
Hi
This error code appears in the frigidaire washer which means--
ddo error--- Dispenser Drawer Open
GLTF1670AS0
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 08, 2009 | Washing Machines
Error code ddo
the dispenser drawer has a magnet in it that has to line up with a sensor. if you can put the drawer back in that will solve the problem. if the magnet isn't lost.
Oct 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Magnet
if it's a small rectangular magnet that appears, in our case, fell out, when you add detergent, softener, etc...the magnet goes on the right hand bottom corner of the drawer face, straight up and down, not sideways. this is evidently some type of sensor allowing the washer to start. we had an error code of "ddo" when the magnet fell out.
Sep 04, 2007 | Frigidaire GLTF2940ES Front Load Washer
Jura Capresso Impressa E8 Espresso/Coffee Maker Logo
1,703 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
