Question about GE Refrigerators
Water running out freezer side of ref. ge tfx22zr
  • GE Master
  • 4,654 Answers
Two possibility's. The defrost condensate pan behind the rear panel of the freezer is blocked by ice or something else. Or the ice maker is leaking. I will help you let me know, Sea Breeze
Posted on Jul 22, 2009
My side by side ge profile refrigerator is causing grief. It starts by water freezing not allowing the water dispenser to work. Then it begins to defrost the freezer side. I also notice that anything in...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 23, 2011 | GE Refrigerators
Hi, We have a ge refrigerator gsh25sgpa-ss. Water is leaking down the back of the inside of the freezer. We have replaced the filter and the water valve, any thoughts?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | GE Profile PSW26P Stainless Steel Side by...
Does GE TFX22ZR side by side have water filter? and how often do we need to replace it and what type?
Your refrig is a older model and does not have a built in filter, if it did it would be in the upper right corner of the fresh food (ref) compartment
Gene
Aug 01, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a side by side ge model TFX20JRBK ref and the ref side has started getting warmer than normal any help wanted
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 27, 2011 | Refrigerators
GE TFX22ZR side by side. ice maker not making ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Oct 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water does not dispens, but ice dispenser works fine.
could be a thermistor,there should be one on ref.side towards bottom of ref.with a white cap over it.behind it is your thermistor.but you also hve them in your freezer.so it is hard to say which is bad.you should have 2 in freezer.they are also white and almost bullet shaped.
Mar 09, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
GE TPX24 BRBJ side-by-side drips water from door dispenser
water valve is behind ref.on either the right side or left but you will see your water line going to ref.water valve.Most likely replace.
Mar 06, 2009 | GE PDS22SIS Bottom Freezer Refrigerator
TFX22ZR leaking water bottom of freezer door
your drain is plugged , take the cover off and air tank hose and blow out the drain , it is simply water build up and flows over to the bottom of freezer, its defrost water from coil , does'nt matter if you have water shut off
Sep 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
