Question about Fellowes 3011001 Shredder
Sounds like a jack hammer
Last week our paper shredder started to make this noise where it sounds like a jack hammer. Then it stopped working. We unplugged it and then an hour later plugged it back in. It started working but is still making the noise. We looked for any stuck paper but can't see any. We also tried putting in those lubricated sheets but that did not help.
Any other ideas?
  • Anonymous Aug 25, 2008
    removed all shredded paper. thought perhaps a paper clip or staple had become lodged. found none. also sounds like perhaps a gear is slipping. shredder teeth run forward and backward when paper inserted but paper will not feed into shredder.
  • 102 Answers
This is more than likely a broken gear in the motor area. You may be able to purchase a gear kit for the machine. Call manufacturer Customer Service. If it is a Fellowes product I gurantee we will help you the best we can.
Posted on Feb 22, 2008
I just bought a Royal shredder, model MC14MX. That's a Sam's model number, so I can't find it online, but it is a 14 sheet crosscut. There was no manual in the box and I can't find one online. The...
On the reviews for this shredder some people mentioned the same thing. Just got mine home, and sure enough, sounds like jars clanking together.
Plugged it in, and started feeding paper into it, and it works just fine. I wouldn't worry about the clanking. BTW makes me smile every time I feed paper in. It is so quiet. My last one sounded like a mack truck, this has a mild hum and a slight bit of clanking.
Jan 20, 2011 | Royal 160MX Shredder
Yesterday when i was using it it started to make a really loud noise. reverse makes the normal noise but on auto it sounds bad. i cleaned out the inside but there is still paper stuck that i cant pull out....
It will not hurt to pour some lightweight shredder oil onto the cutting shafts....depending on how much you use the machine this should almost be part of a regular operation... I normally suggest to customers to pour the shredder oil onto a sheet of paper in an "S" pattern and then shred the sheet of paper....also shredders will work more reliably if you only shred about 70% of the rated capacity...less strain on the motor and parts and this results in fewer jams and longer machine life.
Oct 08, 2010 | Royal VF1012mx Shredder
My shredder makes a thumpping noise then stop. Inreverse it does the same thing. My model is Aurora AS701X-MS The motor runs but it does'nt shred the paper unless you shake the paper then it stops.
It sounds like one of the drive gears has broken. I have contacted this manufacturer before and was told that they do not make replacement parts for their machines. If it is less than a year old, they will replace the unit but that is about all they will do.
Jun 20, 2010 | Aurora Electronics (AS701X) Shredder
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here:
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
Paper Shredder problem Royal JMD500 paper shredder makes a banging noise and paper only shreds about 1 inch in and then stops. You must put machine in reverse to take paper out.
Sounds like shreddder gears are not staying aligned or somethhing is caught in the cutters.
The shredder has a sensor to detect when somethine is insert. Hol the sensor swith down and check for paper clips or staples in the roller/shredding teath. Good Luck and use a match book on the switch to wedge it..
Sep 16, 2009 | Toastess International PV434995 Electric...
I was shredding paper when it started making a loud grinding noise and wouldn't accept any more paper. I've tried running it back and forth, but it only goes, maybe half way, either way, and it still...
This is a very common problem. Go out to the hardware store and buy some silicone spray. With the shredder unplugged, spray a good amount of the silicone inside all of the teeth and try to get all sides.
Plug it back in and work it back and forth a few times. It should work better with less noise now.
Jul 24, 2009 | Fellowes DM15C Shredder
My paper shredder stopped working
First things First...UNPLUG THE UNIT. It sounds like it has been fed too many pages at one time. You may also want to dump any shredded paper so there is plenty of room for the shredder blades to pull in the paper. If the paper catcher is too full the blades can grab shreds from the bottom and stop the blades movement. Just be careful. Shredders can be dangerous.
Jun 01, 2009 | Office Equipment & Supplies
Royal 150MX bumping noise when paper is inserted
Sounds like you may have a gear problem; unplug unit open the top to see whats broken/stripped then call Royal at 1-800-524-0799 for parts and prices.
Apr 20, 2009 | Royal 150MX Cross-Cut Shredder
Paper shredder not working
sounds like the cutting wheels have something jammed inside them , can you take it bak and return it ? or open it up and see if anything looks bad inside ?
Jan 07, 2009 | World Office Products Papermate PM-600C...
Infoguard shredder jam
When you set it to reverse, it Should propel the paper back out the top, where it's jammed. If it does not, remove power to the unit, and get ready for the long laborious process of removing the jam with a pair of tweezers. A hazard of paper shredders, maintenance can be a bit on the silly side.
Jun 03, 2007 | Shredder 1052 (Cross-Cut)
Fellowes 3011001 Shredder Logo
565 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
