Question about Freezers
Ice maker stop working on my Whirlpool gold..md#gb22dkxgw00
Ice maker stop working 3 day's ago , now today frezzer has stop too... please help...
  • Freezers Master
  • 1,606 Answers
Brand and model number necessary to diagnose your problem .
Posted on Jul 22, 2009
Everstar HDIM 35 ice maker
Click below ;
There's no ice
Hope this may help
Jul 30, 2008 | Freezers
Ho do i repair the Ice maker
filter is no problem. Have you inserted it right?
Jul 10, 2015 | Samsung RF260BEAEBC 25.5 cu. ft. French...
F1471 vi Miele freezer showing fault code 01 21 _F
From a previous post for a different Miele freezer: "I emailed Miele and this is what they reply: Thank you for your interest in Miele products. That message is a ice fault. If the ice has stopped production, please turn the toggle switch off under the electronic touch panel. To find this please reference the owners manual on pages 7 and 9. I have included the owners manual in case yours is missing. If your machine still produces ice fine just shake the cubes around making sure none are built up along the back wall of the ice drawer. If this continues please contact our service department. Please reference incident number 2698767 should you need to call in. For more detailed information, please visit our web site at www.miele.com or to speak with one of our representative call 800-999-1360." Haven't tried yet, but will post again if it didn't work, otherwise should be the answer"
Nov 17, 2013 | Miele Freezers
I own a Thermador Freedom Collection 18 inch Built-in Freezer Column with Exterior Ice and Water Dispenser Model T18ID80NRP and have had this unit for approx. 2 years as a companion unit to my Thermador...
No solution but just a warning. We had this same thing happen. They sent a repairman to replace the control board. Then did it again. Just before Christmas, the WATER started dispensing by itself. Luckily, I was nearby and heard it or the damage would have been extensive from flooding. They are now 'working on' getting a response from Thermador. I feel like this thing is just a homeowners claim waiting to happen.
Oct 28, 2010 | Thermador Freezer FREEDOM® T24ID80PLS
Ice maker will only cycle once then it goes to off position . It stop working due to ice build up in supply tube. I removed the ice maker and ran hot water over unit to clear out the ice that was lodged in...
That bar your talking about goes to the full up position just before the end of the harvest cycle then falls right at the end of the cycle. But on a good day it barely drops. Characteristic of that ice maker.
If you ran water over the ice maker try these 2 things.
1. Remove the ice maker and leave it on the counter for about 2 days to completely dry out. Then re-install and try again.
2. If no luck, hang a small weight to the middle of the wire to see if it will drop on it's own.
3. If no luck, you'll have to replace the ice maker. However,
if your commited to buying a new ice maker, first snap off the front cover and look for interference where the wire goes into the ice maker. You can actually remove the whole solid state front end by removing the 3 screws that hold it on and make a more detailed check.
P.S. pull the wire out of the ice maker before this last step. It simply pulls out.
Oct 28, 2009 | Whirlpool Freezers
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Freezers Logo
95 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
