Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Is your machine either the Toshiba AW-SD120SM or AW-SD120SS?
If it is I checked the manual and the error code you mentioned is not listed in their operators manual. On page 35 of the manual there is a message that says "As for information display beyond the above-mentioned details, or the above-mentioned solutions do not work, please disconnect the power plug and contact technicians for repair."
The only codes mentioned are: E1 E21 E23 E31 E32 E5 A ans F
E21: Lid open
E31: Load imbalance
