Question about Sony Walkman D-EJ360 Personal CD Player
Sony Walkman D-NE004
I purchased this Walkman a few months ago. Now when I try and play any CD I get the 'no Disc' message. Have you any idea what might be causing this?
Thanks, Gordon.
  • lz1wkk Dec 30, 2007
    after inserting a CD into player it tries to read information and writes "no Disc" on the display.Help please!
  • lecarlisle Apr 24, 2009
    What is the solution to fixing "the laser might be knackered"
I assume you've tried batteries, cleaned the laser, etc. If so, then the laser might be knackered!
Posted on Mar 20, 2008
Mz-n510 walkman won't play 140 mb disc
No. MZ-n510s cannot play those discs. Buy a HI MD machine or sell the disc.
http://www.minidisc.org/hi-md_faq.html#_q96
Dec 17, 2012 | Sony Net MD Walkman MZ-N510 MiniDisc...
Sony cdp cx 355 skips on first track
Could be some dust or debris in the unit. Also be careful that you are not putting fingermarks near the hole section of each CD you put in, as the CD plays from the centre out.
Jul 02, 2017 | Sony MegaStorage CDP-CX355 300-Disc CD...
SONY Walkman D-NE005 won't play my CDs I am getting a "no disc" message
you may need to contact Sony Support. You're lucky if its still covered by the warranty.
Oct 14, 2010 | Sony Walkman D-NE300 Personal CD Player
Put in clean commercial disc and get error msg "no disc" period!
Dr. OM,
Lets give it a try. The purchasedate will be 1991 (HI).
I'll suppose you allready cleaned the laserunit.
You can try to clean the laserslides, sometimes they are sticky and dry. Then the laser is not fast and precise enough to read the index of your CD.
Clean them with some alcohol on cottontips.
When they are really clean, use just a little teflonoil to make sure the laserunit slides very smoothly.
Regards,
73's Gerard
May 13, 2010 | Sony CDP-C505 5-Disc CD Changer
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
Where can i find a usb for my walkman?
For Few Models, it is available at :-
http://www.handhelditems.com/sony-walkman-nwza815-a818-a726-s615-data-cable-p-13123.html
You could also get it on
http://www.ebay.com
You could also contact Sony :-
http://esupport.sony.com/US/perl/model-accessories.pl
You could also go to the Nearest Wallmart and get it from there. It would only cost you around 7 bucks from there. Earlier, few months ago when i was in Chicago, i purchased it from Wallmart near Elk Grove Village.
Or
If you are unable to find it, let me know the Model and i would be able to tell you where tp Purchase that.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 12, 2010 | Sony Audio Players & Recorders
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Sony cd walkman reads but won't play
If you have a small enough screwdriver and some time it's not too hard. I just fixed one of my kids' walkman (same make & model) yesterday. The motor that spins the gears that makes the laser assembly move back & forth came loose. There is a single screw that holds this motor in place. They should use some lok-tite or similar when they assemble these things.
Jun 03, 2008 | Audio Players & Recorders
RS2635 5 disk changer skipping
your cdplayer is probably at intro
Aug 05, 2007 | RCA RS2635 CD Shelf System
Sony Walkman D-EJ360 Personal CD Player Logo
418 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
