Question about Dishwashers
HOOVER HED60-86 Dishwasher Error Code: Temperature Sensor Failure
Hello everybody, I am Asterios, and I have the following problem with my HOOVER dishwasher model HED 60-86. It is releasing an error code: the pre-wash light and drying light brighten up simultaneously. According to the instruction manual this means a failure of temperature sensor caused by open circuit or break of temperature sensor. Do you have any idea how to fix this problem? Where is the temperature sensor located? Could this be a fault of the control system needing e.g. a reset and reprograming? How to access the control system? Thank you in advance for your answers.
  • 489 Answers
SOURCE: does not go thru dry cycle, clean light blinks 7 times
Remove the front door panel and look for a broken wire.  Usually the broken wire is about 1/3 of the way up from the bottom of the door.  The wire tends to get stuck into the insulation causing the break.  Repair the wire connection and then cover the affected wire harness with a plastic cover to separate the harness from the black insulation.  If there is no broken wire, then the thermistor needs to be replaced.  That will require the entire unit removed to access from the bottom of the dishwasher.  Thermistor failures are very, very rare.
Posted on Jun 11, 2008
jsrock516
  • 5911 Answers
SOURCE: Blinking Green Light
Here's what I could find on the your error code:
A blinking clean light that flashes 7 times and cannot be reset, occurs when the electronic control does not detect a water temperature increase during the main wash. This could be an indication of a failed heating element, in line thermostat, electronic control board and/or wiring. This problem can also occur if the main wash pump becomes clogged and it not spraying sufficiently. I hope this helps you.
PS A faulty door latch can also cause this error code.
Posted on Jun 23, 2008
mosesclive
  • 191 Answers
SOURCE: Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Posted on Jul 19, 2008
  • 3230 Answers
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
  • 18 Answers
SOURCE: Hi All, we have just
YES HONEST ABE CAN HELP.... WERE YOUR DISHWASHER CONNECTS TO THE WATER, TYPICALLY UNDER THE SINK MAKE SURE THIS VALVE IS OPENED ALL THE WAY, ( TURN IT COUNTER-CLOCKWISE...
Posted on Dec 29, 2009
I have a hoover vhd 9163zd with error code E05,what component does it refer to being at fault,where is the component located
Error Code 05 is a NTC fault, either open circuit or shorted.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "E05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component. It could be the sensor or the temperature control module (NTC module).
Good luck.
Apr 20, 2015 | Hoover Washing Machines
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Hoover oph 714d optima 7kg washing machine fault code e05
Hi
Error code e005 means the temperature sensor has gone bad. To fix this error you'll need to replace the temperature sensor. It might have happened that the temperature sensor wires have been disconnected from the main board. To replace the temperature sensor you'll need to disassemble the washer and inspect the drum's bottom for the temperature sensor. Also check the wires coming to the sensor fro any cut.
Please post back for any further assistance.
Daniel
Aug 01, 2010 | Washing Machines
Baumatic WQP12-9213 - Error Code 004?
hello
The "004" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while 004 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the 004 error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Jun 03, 2010 | Washing Machines
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Getting a error code F3E2
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven. This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board. If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe. If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly. I recommend calling a service technician to diagnose and repair this oven failure. If you want to attempt to diagnose and repair this failure yourself, resubmit your question with additional details.
Good luck and please rate FixYa!
Dec 23, 2008 | Whirlpool RF365 Electric Kitchen Range
Error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Dec 18, 2008 | Kenmore Washing Machines
Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Apr 11, 2008 | Washing Machines
Dishwashers Logo
549 people viewed this question
Top Dishwashers Experts
