Question about Whirlpool GU2400XTP Built-in Dishwasher
Potscrubber dishwasher leaks from middle of bottom of door.
Replaced door seal and still leaks
    Scholar:
  • 42 Answers
Try going to the following website "appliancepartspros.com" There you can enter you model number and find all parts needed as well as complete picture breakdowns of your appliance. The also have intructions on how to.......and a blog where you can ask questions, and an expert in the field respnds with replies. I think you will have all your questions answered on the website. I have been using the website for years for all my appliances and have never been steered wrong yet. The prices are the lowest around...low than most even with shipping included.
Posted on Jul 22, 2009
GE Potscrubber,Quiet Power dishwasher leaks while running
Check to see if the door baffles are intact they are little black rubber things in the front on each side of the tub. the pump seal could be leaking underneath. the wrong detergent (dishwashing detergent) could have been used.
Oct 08, 2014 | Dishwashers
Kitchenaid dishwasher door leaks out bottom middle of door when it goes into drain mode?
You probably need to check the door gasket for proper sealing and maybe replace it if the dishwasher has been in use for awhile
Oct 13, 2012 | KitchenAid KUDI24SE Built-in Dishwasher
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
Leaking at the bottom in the middle of the door
you need to determine if it's coming from inside the door or under the front of the dishwasher, if the door latch needs adjusting it can get water through the latch slot, the dispenser can work it's way loose and water can leak through it, or the seal on the bottom of the door can get dirt stuck on it which can cause water to leak out.
Otherwise it could be in the bottom of the dishwasher, it is a matter of closer investigation.
Mar 10, 2012 | GE 24 in. Profile PDW7800 Built-in...
My GE Potscrubber Dishwasher Model # VSD3104X04WW is leaking at the bottom, to the left of the motor. What seal(s) do I require to solve the problem?
the seal you need is the pump seal. The part number for the pump seal kit is WD19X10032 it could be purchased from your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
partselect.com
apdepot.com
repairclinic.com
This youtube video shows step by step how to replace the pump seal kit
http://www.youtube.com/watch?v=Ar8lQNzEPZs
GENE
Sep 10, 2011 | General Electric Dishwashers
When I turn on the GE PotScrubber dishwasher with water, water is leaking out from disher please advise. According from one repair guy, it is related to pump issue please adivse
first try to look and see where the water is coming from,,,the bottom of the unit,,,,or the front of the unit...remember the door has a seal all the way around it and it has to seal correct and make sure the latch is all the way in lock postion
Feb 19, 2011 | Maytag Dishwasher
Frigidaire Dishwasher leaking but not from door
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Jun 30, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher leak
With dishwasher empty and disconnected, find the screws around the area of the "vent",you may need to open it from the bottom. There will be a hose that has either ruptured or just needs the clamp tightened with a screw driver. I think that the hose is a drain or water return. Should be an easy fix.
Oct 31, 2007 | Dishwashers
Dishwasher
GE 720 Potscrubber I started with the water puddling in bottom now it progressed to leaking on the floor. I had a repair guy come to my home yesterday and he says a broken seal and my total cost to replace seal and labor is $165 plus tax.
What is the life expectancy? He did not sound too promising about the future of my dishwasher and said he is certain there will be another repair need shortly something related to the water saturating an area underneath the dishwasher?
He reccomended I call Sears and replace with a Whirlpool product. He claimed he put his kids thru college repairing GE products. My husband wants to repair and I dont because of fear of spending more money!
Jun 18, 2007 | GE 24 in. GSD2600GBB Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
186 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
