SOURCE: Whirlpool AWM8121 ?door open? light flashing
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
SOURCE: The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
SOURCE: Whirlpool Washer gives error code D FL? The washer
Hi
Thanks for using FixYa. Error “fld” means a door
latch failure. This means that you’ll need to replace the door latch assembly
however before doing that you can leave the washer unplugged for 30minutes so
that it resets itself. In the meantime when it’s unplugged just inspect the
door latch wiring to ensure all the connector plugs are intact and not loose or
broken. You can access the door latch wiring harness by removing the top panel
of the washer. To remove the top panel just remove the three screws that hold
the panel in place in the rear of the washer. With the screws removed, the
panel will slide back, and then lift off. Locate the door latch assembly behind
the front panel on the right hand side. Trace all the connectors from the door
latch to the Central Control Unit (CCU) and make sure they are properly seated
at both ends. If after doing this still the issue is not resolved then
unfortunately you have to get the door latch replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
