Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
My kenmore side by side/ model 55771/ is having the same problem.
Freezer and fridge does not cool at all. compresser seems to be very hot. and it sounds like its running but it doesnt vibrate like it should when the compresser kicks on. i let it run for about 2 hours and had no change in temp.
  • Kenmore Master
  • 1,606 Answers
Is the fan running by the compressor and are your coils clean under refrig ? also make sure the cardboard panel is on the back of the refrig .
Posted on Jul 22, 2009
My Frigidaire Model # FRS26LF7DS7 is not cooling!
Could be a few problems. What I would do is check to see if the compresser is running by pulling out the fridge and pulling the back panel off and putting your hand on the compresser. If it Is vibrating then it is running. If it is not vibrating but very hot then the compresser is dead and needs to be replaced. If the compresser Is cool and not running I would say the thermostat inside the fridge is dead(bad contacts in the control). If the compresser is running but no cooling, the cap tube which is the metering device for the refrigerant into the freezer evaperator could be plugged off. Or if none of the lines off of the compresser are hot or cold then the valves inside the compresser are gone and compresser needs to be replaced hope this helps
Sep 06, 2012 | Frigidaire FFHT1817L Top Freezer...
Hi I have kenmore side by side fridge and I want to change wtaer filter but I cannot locate it. Model series noo is 55771. can u please help thanks
It depends who made that refrig for sears,the 3 leading manufactures for sears are Whirlpool and all their filters are in the grill below the the freezer door.,General Electric their filters are in the fresh food (frige) compartment on the ceiling in the upper right corner OR Frigidiare and theirs is right inside of the ref door in the upper right corner by the controls
I hope this helps,
Gene
Aug 04, 2011 | Kenmore 57029 Side by Side Refrigerator
My kenmore fridge model 56723 is not cooling that is the fridge side. the fan is spinning very well but the compressor is very hot. funny enough the freezer appears to be cooling okay
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Jul 23, 2011 | Kenmore 56723 Side by Side Refrigerator
After defrosting the freezer it will not cool
Don't panic about the hot sides of the freezer. It is quite common on all the freezer (make/model).
After defrosting, your removing the full temerature out of the system. It will take atleast 30 ~ 60 mins to come back to set temperature. This again depends on the load inside.
Jun 06, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Freezer and fridge not cooling
is the high side off the compresser hot if not it sounds like you lost the refrigent charge
Nov 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Panel between fridge and freezer hot on Kenmore fridge
It is normal for that panel to get warm while the fridge is running. There is a hot gas tube from the compressor running through it to prevent frost built up. If it's feeling a little too hot try cleaning the coils under the fridge. This will allow the gasses to cool a little more efficiently thus allowing the fridge to cool quicker.
Nov 03, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
628 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
