I have a Kenmore 80 series electric dryer. The light still comes on when you open in the door, but absolutely nothing happens when you hit the start button...any suggestions?
Push the button manually and see if the light goes off . If it does , then the problem is the thermal fuse (a white slim piece of plastic with 2 wires connected to it ) located on the blower housing beneath the drum .
mine just did the same thing yesterday took it apart and found that the thermal fuse is blown so gonna replace that and hopefully solve the problem. i did however jump the wires direct and dryer started.
I have a Kenmore 80 series electric dryer. The light comes on when the door is open so I know it is getting power but dryer will not turn on. Is the push button not working or can I reset the dyer?
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
bypass door switch , if that doesnt work and you have replaced start switch already. then i would unplug unit remove back panel and look for the blower housing , on the blower wheel housing or to the right should be a white thermostat with 2 wires going to it.round shaped and it mounts to the blower housing by pass it and it should work however dont leave it bypassed. hope this helps
