Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Not spinning I have a top load Whirlpool Ultimate Care II washer that's about 8 years old. The Model # is SM 82808667. It loads water and agitates fine but then sits there and doesn't spin. I've tried all the cycles, opened the lid and tried jiggling the contact, but nothing. No sound like it's even trying to do anything. Is this something I can repair myself?
  • 5,911 Answers
This is a common symptom of a lid switch gone bad. I know you stated that you jiggled the contacts, but the switch still may be defective. If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: Some washer models have the lid switch located near either the left or right hinge of the lid. This type of switch is activated by a rod on the hinge pin. If not functioning, it can often be adjusted by bending the hinge rod until it engages the switch.
If you have questions, please let me know. I hope this helps you.
Posted on Jul 22, 2009
Model # SM 8280867 How old is this model?
6 - 10 years in 2012
Whirlpool Washer Ultimate Care ii - Appliance Repair Forums www.applianceblog.com/.../32099-Whirlpool-Washer-Ultimate-Care-ii
  • LAST UPDATED: 2012-05-28
  • 6 POSTS
  • FIRST POST: 2012-05-28
Whirlpool Washer Ultimate Care ii Model Number: SM 8280867 Brand: Whirlpool Age: 6-10 years Hello, The washer ...
Jan 27, 2016 | Washing Machines
Whirlpool model SM 8525079 fills with water but will not agitate or spin
If you have motor sounds after water fill,but no agitation or spin it could be a broken direct drive coupling. If it will not pump out water,there could be something stuck in the drain pump.
Jan 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Drum won't spin - especially when full of clothes. Whirlpool Ultimate Care II LSQ9564J Top Load.
Does it spin without anything in it?
Does it agitate?
Does it pump out the water?
If you said Yes to all of these Im sorry to say this you probably burnt out the clutch.
If it doesnt agitate maybe you will be lucky and you only need a coupler.
If you over load it often and wash large items you probably burnt out the clutch. This is an expense repair. You may want to consider a new washer.
Dec 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Does not spin or empty
it might be jammed or there might be dirt or some sort of a clog. I would suggest you clean it out.
May 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The agitator does't work on the Whirlpool Utimate II & this washer is about 7-8 years old
You must replace the agitator dogs. Pop the top cover of the agitator to access the 4 defective parts. They are pear shaped.
Tools required.
Feb 20, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer does not agitate after filling with water
does it spin?
sounds like your coupling is broke.It takes the place of the belt if it breaks it won't spin or agitate. it will still pump though.
Part # 285753A
Nov 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate care 2 (ABOUT 4 YEARS OLD)
Sounds like the clutch is slipping but sometime catching. Or maybe the transmission is almost gone. Is there a burning smell? If so, probably clutch.
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
316 people viewed this question
Dan Webster
Dan Webster
Sal De
