Question about Refrigerators
My ice maker is not despensing ice, but water works. It is a GE Monogram refridg. Water works, but when you change to ice, nothing happens. when it was acting up, all it would do is dispense crushed ice, even when cubed was selected. Have replaced the seliniod, but did not work. Any one out there have the same issue??
  • Mike Smith
    Mike Smith May 11, 2010
    Did you replace the solenoid in the door (incorrect) , or the solenoid by the dispensor motor under the icemaker ?
  • Refrigerators Master
  • 4,654 Answers
Could you look on the bottom frame of your GE Monogram around the door frame and behind the fresh food section door seal for the model number? The problem most likely is in that control panel that you use to switch from crushed to cubes. Let me know, Sea Breeze
Posted on Jul 22, 2009
Why does my ge pss26lg side by side despense water but no ice?
Just because you get water from the dispenser does not mean you should also get ice made in the ice maker. Fact is there are two side to the water control valve. One for the ice maker and the other for the water dispenser. Is there ice remaining inside the ice maker slots? If not then pour water into the tray until full and if after the water freezes it drops the ice into the ice bin this will indicate a defective=> WR57X10032 Water Inlet Valve If nothing happens and the ice maker tray are full of ice this will indicate a defective=> WR30X10093 Ice Maker Assembly The ice maker is cannot be rebuilt on this model. I am here if you have questions, Thank You, John T Appliance 911
May 07, 2014 | GE Refrigerators
I have a Monogram 48"
http://www.acmehowto.com/howto/appliance/icemaker/check/inletvalve.php
Nov 11, 2010 | GE Monogram Side by Side Refrigerator
Manually add water?
Put 2 cups of water into the maker.
Jun 20, 2010 | GE Monogram ZDI15C Automatic Icemaker
GE refridge icemaker won't work
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Jan 03, 2010 | GE Refrigerators
Hi,I have a GE 42" Monogram refrigerator,model # ZISW42DYB,serial #LS037072. The problem that I have is the freezer is leaking water even if I turn the ice maker off.In a day or two the ice tray fills with...
Good day Paul.
Sounds like your diagnosis is right on. In extremely rare cases the ice maker itself could be at fault. But once again is extremely rare.
Dec 12, 2009 | Refrigerators
Water dispenser has stopped working. Ice maker still works and I've changed the water filter. Still nothing
There are two solenoid valves in the rear of the refrigerator. One that controls water for ice and one that controls water for door dispenser. If the water is not coming through when the button is pushed then have the proper solenoid valve replaced and enjoy. Hope this helps. good luck.
Jul 18, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Ge monogram refrigerator is shooting water/ice out.
The same thing has happened to us with the ice. We just unplugged the ice maker for a few seconds then plugged back in. that seemed to work. hasnt happened in a while.
Nov 27, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Refridge
Sounds like the icemaker mold is leaking so the whole icemaker should be replaced.  Leaking water will get on the icemaker heater and cause condensation which then freezes and makes frost.
Oct 17, 2007 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerators Logo
200 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
