Question about Riso Office Equipment & Supplies
Diffrent picture between the original document and master picture
Hi may problem in riso gr 3750 he teak a diffrent picture between the original document and master picture it is small and not similar between the two .
thanks
  • 22 Answers
You have to go to your page setup and set for the size you are printing. Also you have to go to the machine and look at the size the paper setting is at.. they have to match.. You may be printing 11 x 17 when the paper setting on the machine are letter.. This will do this...cause the machine will auto adjust to fit onto the settings on the machine.
Posted on Aug 11, 2009
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
Riso Rp3700 won't print from computer
We suffer the same issue. Have you find the solution?
May 02, 2013 | Office Equipment & Supplies
Hello we have a RISO GR 3770 - and the cloro drum is stuck in the machine. the green light is not on. how can we get the drum out?
Open front door. If you look at the metal housing below the drum you will see a plate mounteg with two screws. Get it off and you will see a small lever. Turn it right to loosen the drum. Be extremely careful when pulling out the drum. If the drum is not in zero-position it might be a bit difficult (e.g. have a look at the master clamp). Please note that it may be difficult to insert the drum again.
Apr 05, 2011 | Riso RZ390 Duplicator
We have a gr 3750 and when the paper tray comes up the feed wheels do not start up to feed the paper in.Any suggestions
  1. check the upward sensor for adjustments and the sensor on the stripper pad unit for adjustments
Mar 13, 2011 | Riso Office Equipment & Supplies
T18 error sg flashing on my gr 3750, does anyone one know what to do pls?
My assumption is that it has something to do with the Purple ink. If you have a spare try swaping it out to see if the error goes away.
Jun 24, 2010 | Riso RZ220 Duplicator
Riso ? One Stripe in the middle.
Yes you are right. The 'stripper finger' is not lifted enough so it scratches the master.
I know this problem from a GR. But the procedure should be nearly the same for your machine. Behind the back cover you will find a small rubber roller. Diameter 12mm (1/2") or so. This roller runs at the excentic curve of the drum. You might find that the rubber is worn of and so the finger cannot be lifted enough any more. You have to replace it.
(Hint: For a fast momentarily solution you may fix it by several windings of adhesive tape.)
May 04, 2010 | Riso RZ390 Duplicator
Code D-17-236 The Riso just stop working, Why?
A D17 is incorrect master roll installed. This could be caused by a) it IS the incorrect master roll, or b) the RF tag that is inside the master roll has gone bad. Try a new one in the original packaging to help with diagnoses. Make sure they are RISO Z type master rolls specific for an RZ220.
Jan 21, 2010 | Riso RZ220 Duplicator
Riso gr 3750 error T14
Means a clamp error. Inspect the clamp on the drum to make sure it moves smoothly and that that clamping mechanism in the back of the machine works as well.
Apr 06, 2009 | Canon PC-140 Black and White Copier
Riso GR 3770 master make shadow on it how to fix it?
check the dust or any scar in scanner (glass).
Feb 17, 2009 | Riso RZ220 Duplicator
101 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
