Question about GE Spacemaker JVM1640SJ Microwave Oven
GE JE1860BH04 microwave--light works but nothing else
This is a built-in unit and is about 2-1/2 years old. A few weeks ago, it stopped working. Now, if we try to cook with it, there is a faint click and the light goes on, but nothing else. The turntable does not turn, and the normal sound made while cooking is absent. The timer and other functions on the control panel all seem to work, though.
The local service shop wants $60 plus time just to look at it, which hardly seems logical since I can replace the unit for less than $200. But knowing the magnatron has a 10-year warranty is frustrating, in case that's the problem.
Thanks in advance for any help or advice.
    Novelist:
  • 123 Answers
You`ll probably find that it`s the interlock switch on the door latch. When the door is closed, the hooks that protrude from the door enter the slots in the oven casing and press down on the latch switches. DO NOT over ride these switches, replace them or get an engineer in to check them. Ian
Posted on Jul 22, 2009
My microwave oven just stopped cooking. The light comes on and the Motor is running, but much louder than normal.
The magnetron in your microwave has probably gone out. The magnetron is the part of the microwave oven that produces microwaves. If you unit is a built in model, it will likely cost more to fix than a new one. Same thing goes for a countertop unit.
Sep 10, 2012 | GE SpaceMaker Microwave Ovens
My GE Profile Jvm1870sk03 microwave built oven does not work. There is power, the clock, timer works. If I press the button to heat the clock shows it's going on but there is no heating process go
Most likely door switches. Companies these days use switches with small 3/16 terminals and they tend to get hot and make the switch go bad. When I replace them I put in a 20 amp rated switch with 1/4 inch terminals, and a short section of better wire to the switch. If you make better connections it stops the wires from getting hot and the switch will last a long time.
Aug 24, 2017 | GE Microwave Ovens
A few weeks ago our ge JVM1660 quit heating and ge sent me a replacement magnetron. I've heard that the capacitor will discharge after the unit has been unplugged for 24 hours... Mine has been unplugged...
Hi newer microwave ovens have a built in resistor to bleed the power from the capacitor once it is unplugged. Saying this it is always a good safety practice to discharge it.
The factory approved method is to purchase a 2 Watt, 20,000 ohm resistor and touch it across the terminals on the microwave capacitor to discharge, doing this with a tool like pliers so you are not touching the metal tips of the resistor.
Most technicians will use pliers that have insulated handles and touch the tips to the capacitor. I am not condoning that, just letting you know.
May 09, 2010 | GE JVM1660 Microwave Oven
Not working
It sounds like 2 separate problems:
1) One of the cooktop lights may have shorted. Sometimes this happens and causes damage (repairable) to the control circuit board. Sometimes it will result in the lights or fan not working, or not turning on.
2) You may have a bad magnetron. See this FixYa solution.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 27, 2010 | GE Microwave Ovens
Same Problem - Suddenly Died ~2yrs old, very light use.
Probably a fuse inside the unit. Can be caused by overheating or by door switches not working properly.
Sep 10, 2009 | Panasonic NN-P794SF Microwave Oven
GE Microwave/Convection Oven - Door Glass Just Exploded!!!
This happened to us 3 weeks ago with our 3 year old Kitchenaid microwave. Several hours after its last use it just shattered. In doing research I discovered that this has also happend with GE microwaves, all 3 years old. The cause seems to have been a batch of defective glass supplied by a third party. Whirlpool was very quick to cover the cost of the replacement, even though our microwave was out of warrantee.
Aug 27, 2009 | GE JEB1095 Convection/Microwave Oven
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Blinking display of advantium m/w oven
by unplugging the m/w for a few minutes and then replugging the problem is gone.
May 29, 2009 | GE Advantium SCA1001SS Convection /...
GE JVM1650 Microwave Suddenly Stops
Your magnetron tube is leaking RF energy inside and zapping the main board. It is NOT dangerous as any leakage will be contained inside the unit. You will need a new mag tube and it is covered by a 5 or 10 year parts warranty. Call GE Factory Service at 1-800-432-2737or schedule online at www.geappliances.com
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
356 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
