Question about GE Refrigerators
Ge refrig. express chill flashes the word hrs
Ge refrig. express chill flashes the word '' hrs'' cooling fans not working...no digital display. ''cycling'' noise - clicking from back of frige...??
Sea Breeze
  • 4655 Answers
SOURCE: GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Posted on Oct 25, 2007
SOURCE: ge refrigerator model gss22wgph bb
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
Posted on Sep 16, 2008
tomsat69
  • 219 Answers
SOURCE: Maytag Fridge MTB2156GEW Won't cool. Change thermostat today and ran it for four hours. Frige was warm after. There is a clicking noise every 2 to 5 minutes from the back of the fridge. I think it is
Yes you have a bad relay on your compressor.Remove the rear panel and take off the relay on the compressor shake it.If it sounds fried then you need to order new on .Just give your model# to your local parts depot and ask them to order you a new compressor relay hope i fixya:)
Posted on May 20, 2009
bruce505
SOURCE: clicking sound - not cooling
The problem is most likely the condenser fan motor at the back-side/bottom/right of the unit. If this fan is not turning, unplug the connector to this fan (inside the protective cover on the wires near the fan)... if the clicking stops, then this fan needs to be replaced.
What is happening is that this fan has failed but continues to draw a heavy load from the circuit board... It draws enough power from the circuit board to drop the voltage on the circuit board to 5-6 volts and the relays on the board open up and disconnect the power to the fan. The the voltage jumps back up to 12-13 volts and the relays turn back on causing the voltage to drop again and the relays to open.... ON....OFF...ON...OFF..... thus the clicking!
The exact part number for this fan may vary depending on the model and serial number of your unit... My model is GBS22K-BRBBB and the fan part is WR84X10055 and should cost $60-$70 though I have seen it being sold for as much as$130.
Posted on Oct 01, 2009
SOURCE: GE Refrigerator: GSS22SGRF SS - Not Cooling; Not dispensing ice or water; clicking noises
U need a new wr51x10101 heater harness 35.50 $ there is an ice build up on your coil defrost coils replace the heater harness U should B good to go
Posted on Sep 07, 2010
I have a GE Profile Artica, This am the unit stopped running and the adjust temperature displays were both blank. The letters hrs appear in the turbo cool display. I unplugged the unit for 1 hour and...
The "HRS" indicator is referring to hours and is related to the Quick Thaw or Express Thaw mode. If the Quick Thaw or Express Thaw feature is turned off then the "HRS" should disappear. However, it this is not the case most likely you will need to replace the main control board.
Dec 31, 2017 | Refrigerators
Both freezer and refrigerator stopped cooling. Electronics on and both setpoints set below normal temperature. Express chill gets fans going but no cooling.
the compressor must be check it's either the freon is low and need to be replace or the compressor is weak..
May 10, 2011 | GE Refrigerators
New floor model. Not cooling. Code on the door says "FF".
Not real familiar with Kenmore specifically, but I think your refrig is in the display mode, so the lights will work, but it won't run while on the sales floor. I suspect it says O for the freezer temp and FF for the refrigerator section. (which is "OFF", commonly the opposite of the ON condition. ) Hopefully, your manual addresses this situation. It may require a procedure such as holding the ice plus, bost, express chill, etc. button and the freezer increase temp button for at least 3 seconds while one of the refrigerator doors is open.
Jan 25, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Have a GE sidebyside REfrig. About once a week
The fan motor is not working properly, call a tech and let he decide otherwise check if your fridge have main control board, that can be other issue
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side-by-Side Refrigerator gets to too cold
turn the temp setting up to40 then check in a couple of hrs
Nov 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Power is on but no control indicators are visible and the letters HRS are flashing inside one of the indicators inside the door. The refrigerator model is a pss26ng GE Profile Arctica
Unplug this refrig from the wall, let sit for one hour, then plug back in, if it starts then you may have a start device on compressor that is bad, more than likely it won't, normally the HRS means there is a "main board" problem. Main board is located on rear of refrig.
Oct 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
A clicking sound was coming from behind my fridge and the temp display was not working. digital display. the light in the fridge comes on but the fridge is not working What could it be?
You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
Sep 24, 2009 | GE Profile PDS20MFS Bottom Freezer...
GE Arctica intermittant clicking sound, panel flashes "hrs"
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Unknown fault code flashing in my now defrosting fridge
OK we have either a main control board pe a temperature control board defective. Will need some one to unplug the refrigerator and on back examine the control board on both sides. Look for burn marks or signs of heat.
Like in this photo.
Here is a photo of the temperature control board.
If you have any questions I sponsor Repair Clinic and feel free to email me or visit my website.
SITE=> http://appliancepartsse.blogspot.com/
Email=> appliancepartsse@yahoo.com
Thanks, Sea Breeze
Jul 29, 2009 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
