Question about Samsung DLP HL-P5663W 56" TV
I have a Samsung HL-R5067W DLP HDTV. I have HD cable from Comcast. My TV plays the HD signal flawlessly. The non HD channels have columns and rows of colors on the screen. The picture can sort of be made out in the background. The same thing happens with a DVD or my WII. Can you help me?
    Problem Solver:
  • 7 Answers
This could be 1 of 2 things--either the light engine or the digital board--i'm betting on the board because hd cable is good--light eng/cost prohibitve--board maybe !!
Posted on Jul 23, 2009
Samsung dlp HL-R5067W sound no picture
Check for open or leaky capacitors look for bulge on the top of caps
Mar 28, 2014 | Samsung Hl-r5067w 50-inch Hd-ready Dlp Tv
TV only works on HD stations
Your TV has an SD/ED component input and an HD component input. You are using the HD input. It can only accept HD signals. You need to correct the settings in you cable box. You need to "fix" the video output so that it converts everything to HD. If you have a motorola box, you can usually turn the box off and press the menu button to access the cable box setup menu. Set the 4:3 override to Stretch or Full. If you need more help with this, post back with more information: cable provider, cable box used. I hope this was of some assistance.
Mar 28, 2010 | Samsung DLP HL-P5663W 56" TV
Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Nov 28, 2009 | Samsung HL-R4667W Rear Projection...
I cannot tell the difference between my SD channels and my HD channels. I have samsung DLP tv, HD cable box and bose theater system. I am using an HDMI cable but there is not difference between that and...
In most cases you will not be able to see a great difference between HDMI and Component connections. As far as not seeing a difference between HD and SD signals from your cable box, go into the settings of it and see what resolution it is putting out. If you have a Motorola cable box, with it off and the TV on press the menu button and the setup screen will appear. That will tell you the output resolution as well as what the 4:3 override is set to. Please take a few moments to rate my answer. Thanks....
Nov 22, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a Samsung HL-S6186W 61" DLP HDTV I could get the hd channels over the air with an antenna before but now I can't get any thru cable without going thru my dvd recorder tuner first which degrades the...
Select TV input, Press Menu, Select Channel, in menu Antenna=Cable (for you), (then perhaps, Auto Program with Cable or Air+Cable), tweak Channel List, turn on LNA if needed, shouldn't be.
Somewhere there may be different modulations, some offset the channel a fraction and are important for channels above 13. I'm basing this on my non-cable Samsung HL-T5687.
BTW, I had an HLS until it gave trouble, paid for an upgrade to LED from bulb when I got HLT. Very pleased, until it fails. -Ken
Jul 15, 2009 | Samsung DLP HL-P5663W 56" TV
Can't get clear picture on my 50" Samsung DLP
Most of the Analog viewing will be much poorer compared to HD. Since it it a digital product, it is designed to be used with a digital signal. You will get signal degradation if it has to take the analog and convert it to digital to be viewed and there is really nothing that can be done to compensate for it.
Hope this helps,
Skyassoc
Jul 04, 2009 | Samsung DLP HL-P5663W 56" TV
Remote Code Samsung 50" DLP HL-R5067W
022 036 043 159 160 170 175 212 215 702 713 706
Dec 14, 2008 | Samsung 50" Slim-Depth DLP HDTV
No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Samsung DLP HL-P5663W 56" TV Logo
339 people viewed this question
Henry  Thomas
Henry Thomas
