I JUST WANT TO FIND THE DAM MANUAL FOR MY HEIL SUNDSTRAND OIL FURNACE A1VA-7012 CAN ANYONE HELP?????????????????
  • 11,896 Answers
[PDF] 2100-016 (1976 11)File Format: PDF/Adobe Acrobat - View as HTML
Operate the manual reset button on top of control. ..... 19 Fuel Unit - Sundstrand A1VA-7012. 20 Fuel Unit Mounting Screw. 21 Oil Line Fitting ...
www.bardhvac.com/digcat/volume_3_cd/install.../2100-016.pdf
Posted on Jul 22, 2009
Heil furnace electronic ignition module red light flashes
the flash codes are usually on the control box or the back of the furnace door
Jan 02, 2013 | Heating & Cooling
Heil furnace lights but wont stay lit 1990 model
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Mar 04, 2011 | Honeywell International Heil Quaker...
We recently purchased a home with a heil furnace and I need to know what size filter it requires. It is a gas heil model # NUG1075DF01. Please help !
That is hard to answer but I would say that for a furnace of that size you are probably looking at somewhere around 16x20x1. On older heil furnaces they often had the filter mounted inside the blower compartment so if the case you can just remove the cover and measure it. If not it should be located on the return air duct close to the furnace. Hope this helps you some. Thank you.
Dec 30, 2010 | Water Heaters
HOW DO YOU KNOW WHEN PUMP IS BAD A1VA-7012
The easiest check to see if pump is working is to disconnect the jet line (small oil line running from pump to the drawer assembly), from the drawer assembly, put into a small cup/container and turn the unit on. You should get a solid stream of oil coming out of the line.
If you do not get any oil, remove the pump from the burner chassis, and ensure that the coupling connecting the motor and pump is intact, and that it has not stripped out.
Hope this helps
Nov 17, 2010 | Heating & Cooling
I need a Manual for a Sundstrand series 15 pump
I just found this free PDF. It is sundstrancd series 15 service manual. It certainly did not answer all my questions but its a good step forward.
www.cushmantrackster.com/pay-pdfs/sundstrand.pdf
Oct 10, 2009 | Danfoss Sundstrand-sauer-danfoss...
Heil Gas Furnace Filters
the filters will go by your blower compartment remove the doors at the furnace and look where the sheet metal opening meets the furnace
Jul 17, 2009 | Heating & Cooling
Heating & Cooling Logo
652 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
