SOURCE: problem with analog recording on Yamaha CDR D651
Your assessment that it duplicates CD's internally fits with an analog-only failure mode. Let's make sure the signal is getting past your RCA jacks on the deck...
Put the deck in a Rec/Standby mode and make sure an analog source registers adequate volume on the meters. If it's good there and doesn't change with cable swapping between the input channels, you're right, the problem is internal. Maybe the volume potentiometer itself has developed a dead spot. Manually rotate it throughout its range many times to wipe it clean.
If you have an external optical digital source use it to check the meters in digital recording mode to be sure they're about even. The same knob affects analog and digital levels.
If you have the deck connected via the traditional Tape Monitor circuit in a receiver you should be able to tell by ear if the one channel is dead or too low. This puts all of the recording circuitry including the volume knob in line with your receiver.
SOURCE: Yamaha CDR -D651 recorder
If your looking for manual or operators guide try Yamaha.com they have most manuals and schematics available.
