Question about Toshiba Satellite A70-S249 Notebook
WHY THE POWER IS NOT SWITCHING OFF?
WHEN I TURNED IT ON, THE COMPUTER REMAINED ON THE STANDBY MODE. WHAT IS THE PROBLEMS?
  • 201 Answers
Go to start,settings,control panel,power options,advanced/select power button from standby to shut off
Posted on Jul 22, 2009
Emerson lc370em2 will not turn on just flickers
Hello Mike, seems you have a problem with your power-supply board....*or check if the tv switched back into standby mode..if tv switched back to stanby mode .....please check your A/V <Main proccessing Board...
Hoping to inform you correctly I remain,
Yours friendly.
Blessings.
Gladmar.
Mar 15, 2014 | Emerson Televison & Video
Stereo amplifier remains in standby mode
You should be able to find a Universal remote that will cancel the standby function.
Mar 31, 2013 | Audio Players & Recorders
Power switch
The red standby light is always on. It should only change when you press 'power'. When you turn it off, it is on 'standby', meaning you can switch the switch to make it start-up in play or record mode by using a timer and the switch below the power switch. This is normal for Sony.
Feb 24, 2012 | Sony MDS-JE330 Mini Disc Player
Please can you help us. when we turn the computer on the monitor light stays blue with the screen remaining black, when we turn the tower off the light stays blue when it usually has the orange standby...
There is probably a conflicting setting in your power management options. My recommendation is that you check the monitor setting in Windows and see how you have it set up. In Windows it is under CONTROL PANEL>POWER OPTIONS. There are a few differences between WINDOWS 7 and XP from here on out, but in general, do not select a scheme and do not select any hibernate, standby, or sleep modes. If you stick with a simple power saving option, like "TURN OFF MONITOR: After 15 mins." you should not have any further problems.
Many of the Windows "green schemes" will not work right with different combinations of BIOS, Hard drive, motherboard, and monitor. It is best to avoid them, unless you are very patient and willing to go the trial and error route. Good Luck!
Mar 08, 2011 | ViewSonic VX2235WM Monitor
When plug in power cord, set turns on demo mode.No respons when press standby/on butten. By pressing tuner or any function butten, set turns off. What may cause this problem? ingberto@hotmail.com With...
The words "Demo Stop/Clear" are right there on the left-hand control knob.
http://www.p4c.philips.com/files/f/fw-c788_19/fw-c788_19_dfu_eng.pdf
Page 13...
To activate the demonstration
 In Standby mode, press and hold DEMO
STOPçon the system until "DEMO ON" is
displayed.
?žœ The demonstration will begin.
To deactivate the demonstration
 Press and hold DEMO STOP çon the system
until "DEMO OFF" is displayed.
?žœ The system will switch to Standby mode.
Note:
- Even if you remove the AC power cord and
reconnect it to the wall socket, the demonstration
will remain off until you activate it again.
Jan 22, 2011 | Philips FWC788 CD Shelf System
I turned on my computer the power light keep blinking and my computer will not come on
Your computer is in STANDBY mode..
To bring it back....There will be a SLEEP/ STANDBY button on your keyboard...press it..
This should solve your problem...
ELSE....
There is problem with your SMPS(Switch Mode Power Supply) which is in your CPU case..Try Replacing it..
Jun 15, 2009 | Dell Dimension 4700 PC Desktop
Screen gone dark
It is natural to ipod the screen will be dark if has no power unless the LCD of your iPod is defected even it has a power its remain dark that’s the symptom of defected LCD screen. I hope your problem is a power failure only. Make sue your iPod is fully charged and then toggle the hold switch on and off. Then reset your iPod nano; Toggle the Hold switch on and off,(Slide it to Hold then it off again). Then press and Hold the Menu and Center (select0 buttons simultaneously until the apple logo appears ,about 6 to 10 seconds .You may need to repeat this step . If you having difficulty resetting your iPod set it on a flat surface .Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel,and not near the center. Then If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try your iPod nano with a different USB port on your computer, not a USB port on your keyboard or hub. iPod will stop charging if the computer, or portable computer, it's connected to enters standby, hibernation, or sleep mode. To charge your iPod, connect it directly to a computer's USB port and make sure standby, hibernation, or sleep mode is turned off. If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly. If you have an Apple iPod USB power adapter you'll be able to charge your iPod without leaving your computer powered on. If all procedure above for power to on is not working then its better to replaced the battery with anew one so its works normal again.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Apple iPod nano
We have a large tube pansonic wide screen tv. it sometimes would stay in standby mode and would not turn on when using the remote or channel switches on the tv.. this is getting worse to the point where...
This fault can be caused by low secondary supply voltages often caused by the value of capacitors becoming low and requiring replacements but you will have to have a technician.
SUPER8
Dec 01, 2008 | Panasonic Televison & Video
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
Toshiba Satellite A70-S249 Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
