MY ESTATE TAWS800JQ1 WASH MACHIN STOPED SPINING
I took of the CABINET and in the bottom close to the motor I found a round belt ripped off can any one help me to get the part number for this and how to restole this black rubber.
thank you
jack
  • 5,911 Answers
The round rubber "belt" actually sounds like your motor coupling. This is a very inexpensive and straightforward repair job if this is the case.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking.
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 22, 2009
How do i unlock my washer there is no code and the power bottom won't go on plaese tell me what to do?
is the machine full of water if so take the discharge hose out of the stand pipe and empty the water in a bucket low to the ground once the water has empty you should be able to open the door if not tilt the machine back and try then clean the blockage ie pump or filter anymore help let me know
Nov 24, 2011 | Samsung WF203ANW Front Load Washer
My estate whirlpool washer model# taws800jq1 water wont shut off when you start cycle
See this tubing:
If this tubing gets sediment in it OR vibrates loose OR gets pinched from re-installing the cabinet OR if the tube gets a hole in it then the pressure won't build up as the water level rises and the water will not shut down. The component that tube is attached to it the water level switch. The likelihood of it being bad is slim. Most of the time sand and sediment gets into the tubing and simply blowing it out and reattaching the the tube to the switch fixes it. Be sure to pump out water after cleaning and re attaching the tube to the water level switch. Service manual and more
Nov 08, 2011 | Estate TAWS800JQ Top Load Washer
Estate Washer (top loader) by Whirlpool. Model Number: TAWS800JQ1 Water will not drain from machine after ten minutes through rinse cycle. It just stops (just shuts itself off) What do we do??
Most likely it is your pressure switch. Locate the switch on your machine and look for damage. if you have a multimeter use it to find any electrical issues if there is no reading the pressure switch needs to be replaced.
Jan 29, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Stoped washing, stoped spining, stoped agatating
Hello, welcome to FixYa.
Based on your description it sounds like a lid switch problem.
Here`s how you can check it pretty easily...
Lift the lid, if you observe the underside of the lid there will be a plastic "strike" or "actuator" that goes into a hole when the lid is closed.
Check the hole where the actuator goes into the cabinet and insure you can see a gray oval shaped piece. If so take a small screw-driver, pen/pencil or something small enough to fit thru the small hole and try activating the switch by pushing it down ( machine must be in the agitate or spin cycle ). If you don't see it, the switch has likely broken loose and needs to be replaced.
If it start's to function than the switch is not being contacted properly by the actuator on the lid and likely is due to the switch being worn...unless the actuator on the lid is broke, if so there`s the problem.
Make sure the switch is being held in place via the two screws along the side, if they are loose tighten them, if it is broken, it will need to be replaced.
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know what you find and if I can assist you further.
good luck.
macmarkus :)
Aug 16, 2010 | KitchenAid KAWS850L Top Load Washer
Taws800jq1 spin cycle belt fell off would like to know were it goes
There is actually no belt on your washer it is a direct drive. You may be talking about the rubber from your coupler which would be a part number 285753a and would be in between your motor and transmission. If the unit is not spinning this would be most likely your problem. Hope this helps. _MJ_
Jan 28, 2010 | Estate TAWX700JQ Top Load Washer
How can I tell the age of my washing machine?
I would have to say from looking up your owners manual and the copy right date it is about a 2000 model.
Jan 04, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
ESTATE TAWS800JQ1 WILL NOT SPIN
both of your problems are the clutch assembly if you are handy you can do this repair
Dec 04, 2007 | Estate TAWS800JQ Top Load Washer
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
121 people viewed this question
Top Washing Machines Experts
