Question about Refrigerators
I have a 3 year old Amana top refdg. with a bottom drawer freezer. Every 6 to 8 weeks the condensing coil with the fins will become frozen, and the refdg. will no keep cool. When this happens, I take a heat gun to de-ice the coil, and it starts to work fine. Why does this keep happing and how do I solve the problem?
  • Refrigerators Master
  • 1,606 Answers
You have either a bad defrost timer , defrost bimetal , or heater . Turn the fridge into defrost manually (find the tech sheet telling you how ) and check the amps in defrost . If above 2 amps , then timer is bad . If no amps , bimetal (small cylinder with 2 wires ) on top of coils , or heater is bad .
Posted on Jul 22, 2009
LG French door bottom freezer unit is only 5 years old. Bottom freezer suddenly not keeping food frozen. Ice cubes are melting, ice cream is soft, and there is water on bags of frozen food in top basket...
You have a defrost condensate drain blockage where all the water from defrost remains inside the freezer compartment and causes the symptons you are having. I cannot tell you how to remove every model numbers freezer rear panel but I think that if you study over my link here=> Leaking Refrigerators and this link HERE you will get an idea of what to do. I am here to answer any questions, Sea Breeze
Aug 09, 2013 | Refrigerators
We have a 22CF Refrigerator Model MFF2258VEM bottom Freezer, only 2 years old. It leaks Water once a day and it started about 3 weeks ago,on the left side onto the floor. We have shut off the water to the...
The problem your having is the defrost drain is blocked,to access the drain the freezer drawer must be removed then remove the back panel of the freezer,to remove the drawer pull it all the way out,look and find a phillips headed screw on the outer side of the slide rail near the door remove those screws(one on each side) lift the drawer off of the slide rails,remove rear panel and the drain will be under the evaperator coil(the stainless steel coil) BEWARE the fins on the coil are very sharp and will cut you. if you dont think you can do it call for service and tell them that the defrost drain is blocked.
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Maytag 21.9 Cu. Ft. Bottom-Mount...
I have an amana bottom freezer/refrigerator model ABB2522FEQ. the bottom freezer works great, but the coils have frozen two times. I thawed coils out again and it only lasted 2 weeks, eventhough the fan...
HI,IF THE FREEZER IS BUILDING ICE ON EVAP COVER THAT IS NOT DEFROSTING PROPERLY,REPLACED THE CONTROL BOARD AND DEFROST B-METAL TO REPAIRD THE PROBLEM..
Jul 04, 2011 | Amana ABB2524DE Bottom Freezer...
Refrigerator is warm, but freezer is cold and still making ice. This is a 3 year old Amanna Bottom Freezer model. There is frost in the top of the freezer drawer when I putt it out.
you will need to defrost it. the freezer is what keeps your fridge cool. the vent where the cool air goes up to your fridge is sealed or frozen.
unplug the fridge and open the doors and let it defrost.
plug it back in after a few hours and it should be working again.
Mar 20, 2011 | Amana ABB2223DEQ Bottom Freezer...
Water is collecting in the bottom of the refrigerator below the drawers. Water was also in the lunch meat drawer.
Your freezer defrost coils are probably frozen. Or the drain tube is plugged. Remove the rear panel from the freezer and defrost the defrost coils if necessary. Make sure that the drain tube underneath the coils is not plugged with ice or other foreign matter. You may have to thaw out the tube. If you don't make sure that the tube is clear, excess condensate will continue to drain into the fridge. Good luck!
Sep 21, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Bottom freezer suddenly had condensation and light wasn't working
That could be the fan in the freezer with ice build up in the area of the evaporator coils which would indicate a problem with the auto defrost system the evaporator coils are behind the back panel of the freezer .
Aug 30, 2009 | Amana ABB1927DE Bottom Freezer...
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Sub Zero isn't cold enough
Sounds like it might just be a simple as a dirty coil. Use a coil brush (you can get at homedepot)
cdda64b.jpg Clean the dust and from the back and bottom of the fridge. The coils pickup alot of dust over time making the fridge become ineffecent. One some subzero units your condenser coils are on top. Use the brush in conjuction with the vacuum to get it clean and watch your fridge for a hours to see if that helps before you call a repair tech out. Make sure you unplug the fridge when your doing this.
Jan 29, 2009 | Sub-Zero Bottom Freezer Refrigerator
Whirlpool Refrigerator not cooling properly
I would try replacing the defrost timer and cleaning the condenser fins.
Apr 19, 2017 | Whirlpool ET1FHTXM Top Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
