SOURCE: Watch has correct day and date only 1/2 each day
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
SOURCE: Adjusting a digital watch
Yes you can adjust digital quartz watches,there be a trimmer inside to adjust the fast and slow.,but that is last option to do if nothing happens.I think when changing the battery you did not clean the battery terminals,so that film residue will gone out.Film residue comes from the liquid comes out from the old battery.this is the most common problem of the battery.After all you clean,next is short ,the terminals.If you forgot this step this is very problem at all,the not working so you better watch out.
SOURCE: Casio 3747 Wave Ceptor is 3 hours 52 minutes behind...
Paste this link into your browser and download pdf file:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3747.pdf
Read carefully about Radio-controled time keeping and other related chapters.
If after performing all the required operations your watch still does not work properly, you have some kind of fault in the Integrated Circuitboard and will need to seek for watchmakers help- probably an IC replacement.
Do not forget to rate, please.
SOURCE: newly changed battery and the time keeps falling behind.
Either bad battery or wrong battery.
SOURCE: New quartz analogue watch losing 5 minutes a day.
not often so . beleive you me from an avid fine watch collector . it's the batteries. hopt this helps.
Standard-quality resonators of this type are warranted to have a long-term accuracy of about 6 parts per million at 31 degrees C (87.8 F): that is, a typical quartz wristwatch will gain or lose 15 seconds per 30 days (within a normal temperature range of 5 deg C / 41 F to 35 deg C / 95 F) or less than a half second clock drift per day when worn near the body.
If a quartz wristwatch is "rated" by measuring its timekeeping characteristics against an atomic clock's time broadcast, to determine how much time the watch gains or loses per day, and adjustments are made to the circuitry to "regulate" the timekeeping, then the corrected time will easily be accurate within 10 seconds per year. This is more than adequate to perform celestial navigation.
Assuming that you have a computer with internet-synced time and good internet, meaning around 1/100 second accuracy, why not compare the watch to the computer over the space of a week?
