Question about AudioBahn A2300HCT Car Audio Amplifier
A3200e wattage how many watts is this amp?specs? i cant find any info on this amp online, i only find reviews
    Genius:
  • 1,114 Answers
Here are some specs:
  • 4800W Max, High-Current 2-Channel Car Amplifier
  • RMS Power Rating:
    • 300 watts x 2 chan. @ 4 ohms
    • 600 watts x 2 chan. @ 2 ohms
    • 1200 watts x 2 chan. @ 1 ohm
    • Bridged:
      • 600 watts x 1 chan. @ 4 ohms
      • 1200 watts x 1 chan. @ 2 ohms
      • 2400 watts x 1 chan. @ 1 ohm
  • Max Power Output: 4800 watts @ 1 ohm
  • this is the web site I got the specs from
  • http://www.sonicelectronix.com/item_61_Audiobahn+A2300HCT.html
  • Hope this Helps...
  • Posted on Jul 22, 2009
    Can I install 4500 wt elements in a marathon MR50238? The tank specs are the same as MR 50245.
    1) Product warranty will be voided if you install 4500 watt elements in year-2008 model MR50238 3800 watt marathon tank.
    Older 3800 watt element models have been discontinued.
    2) Copy following links for Marathon resources:
    http://waterheatertimer.org/Review-Rheem-Marathon-water-heater.html
    http://waterheatertimer.org/How-to-replace-water-heater-element.html
    3) Product warranty is voided if element wattage exceeds label on side of unit.
    4) Marathon has a problem with elements burning out frequently.
    To solve this problem, they suggest installing element with lower wattage, such as the 3800 watt.
    Upper 3800 SP610130
    Lower 3800 SP210197
    Feb 20, 2013 | Water Heaters
    I want to find out how many watts does the kenmore 400 series uses
    Maybe a dumb question, but what do you need a transformer for a washing machine? Washers typically plug into a standard 120 volt 15 amp outlet. To figure out the wattage, use the simple formula, P=E x I. There will be a tag somewhere on the machine stating current draw, which is "I", "E" is your voltage, and "P" is your wattage which is what you'll figure out after reading the label on the machine.
    Jul 23, 2012 | Kenmore Washing Machines
    What is the output for a JVC RX-317? whatever it is .. is that sufficient enough to push a frequency response 40hz-25kHz?
    What kind of question is this? Push a frequency range with no other context??? Heck, sight unseen I'd say yes but it would be meaningless without the following considerations...
    Amplifiers push POWER (Watts) through a specified LOAD (Ohms) within a freqeuncy bandwidth at a specified + or - dB level and with less than a specified amount of distortion for comparison to other amps.
    Besides, 40hz-25kHz is itself deficient on the bass side and ultrasonic overkill on the high side. The range of 20-20K is more commonly used for audio specs. From the few user reviews I found I imagine it will push 80-100 watts cleanly into 8-ohms across the audible bandwidth. Like any amp, exceed its capacity at the risk of its and your speakers' well-being.
    I can't find any authoritative specs for it.
    Sep 14, 2011 | JVC RX-317 Receiver
    I bought a new panasonic home cinema model number sc-pt480eb-k. Its supposed to be 1000 watts but the output it doesn't match that output at all even with all the speakers on. What maybe the cause of this...
    Hype on the part of the maufacturer's published specs.
    http://service.us.panasonic.com/OPERMANPDF/SCPT480.PDF
    Look at the Power Comsumption spec on page 22. "90 watts"
    According to this post, 45 watts...
    http://reviews.cnet.com/home-theater-systems/panasonic-sc-pt480/4507-6740_7-34024832.html
    It would be a miracle indeed to extract 1000 watts of sustained power in any form, be it heat, light, motion or sound from a unit that uses anything less than 1000 watts of electricity, assuming 100% efficiency. Not to mention the dreadful 10% distortion level they use to get that figure.
    To say it pushes 1000 watts is dishonest and preys on the gullible.
    Apr 10, 2011 | Panasonic Audio Players & Recorders
    Just bought 2 12 in d3 dual 2 ohm subs with d5 600.4 amp. Need to know how to wire subs. They were in a box already I assumed they were wire at 2 o When i hooked One up to my amp it hit really for Jus...
    what wattage are the subs and amp? if your subs are more wattage than your amp, your amp will blow fuses as cant handle the output to your subs. for example. you have 2 500 watt subs and a 300 watt amp, that is no good as amp isnt powerful enough. if you have 2 500 watt subs you need at least a 1200 watt amp to power them both. 200 watt more than the combined wattage of subs as amps should never be turned up to max as they tend to blow and overheat more quickly. 80% volume on amps is reccomended by installers and manufactures.
    Feb 27, 2011 | Diamond Audio D5-600.4 Car Audio Amplifier
    Power out rms- 4 o 8 homs?
    I can see why you're asking for help on this. It almost seem this unit has been 'disappeared' as far as online information is concerned. Even Sony has nothing on it.
    I founs some articles and For Sale posts:
    http://toronto.kijiji.ca/c-buy-and-sell-electronics-Sony-STR-4800SD-Stereo-Receiver-135-OBO-W0QQAdIdZ243602516
    "Sony's STR-4800SD receiver was extensively, and positively, reviewed in Stereo magazine's Fall '77 issue. In their introduction, they found the 4800SD bettered its published f.m. sensitivity specs "by a wide margin...it has exceptionally smooth frequency response, very low distortion(especially in the midband), and excellent quieting. No exotic claims are made for the power amp section, either (35 watts/channel,15.4 dBw at 0.2% THD). But our tests indicate much more capability than that, and a distortion of only one-tenth that spec."
    The power consumption figure shown in a photo below says "145W", which would be consistent with a 35 watt amplifier.
    http://www.oaktreevintage.com/web_photos/Stereo_Receivers/Sony_STR-4800SD_Stereo_Reciever_collage.jpg
    Jan 02, 2011 | Sony str-4800sd stereo receiver with...
    The model number is Kenwood KA-894 integrated Amplifier I'm trying to find out how many watts. Thanks
    The manual with 'specs' is here. Take them with a grain of salt because it's impossible to produce more audio watts than are consumed electrically (250 total).
    http://www.retrevo.com/s/Kenwood-KA-894-Amps-review-manual/id/479ag211/t/1-2/
    Dec 25, 2010 | Audio Players & Recorders
    What type fuse does this model use
    Reviewing the specs on this inverter, there is no mention of the fuse, but past experience tells me that the portion that inserts into the cigarette lighter would be the likely location. Try unscrewing the knurled portion at the tip. be careful because it may be spring loaded. Remove this assembly and a glass fuse may be located there. Check for continuity on it. You can go online and purchase the same fuse at newark.com
    Dec 03, 2010 | Inverter Vector Power - 70 Watt, Model...
    Kenmore top mount refrigerator, 18 cubic feet. how many amps doe it use. question is for purchase of emergency generator. spec Plate states 4.5 amps, is that accurate? Refrig is 115 volts, 60 hz
    Good day,
    That sounds about right, however if your generator is rated in wattage the amps times volts won't work.
    On an induction unit, such as a refrigerator, the wattage is volts times power factor times amps.
    Nominal wattage should be around 375 watts. However, during auto defrost the heater will probably be around 450 watts.
    As well, locked rotor amps on starting will be about 4 times running amps approx. 18 to 20 amps. so your generator will have to be able to handle that.
    The short and long of it is give yourself wiggle room.
    Aug 24, 2010 | Kenmore Refrigerators
    AudioBahn A2300HCT Car Audio Amplifier Logo
    346 people viewed this question
    Top AudioBahn Car Audio & Video Experts
    Tygh Duval
    Tygh Duval
    Colin Stickland
    Colin Stickland
    Jerry Naidoo
    Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
