55 inch Mecer LED monitor. sound from on board speakers used to work until my son fiddled with the remote. now no sound is heard no matter what buttons i press on remote eg mute and volume control.
Hi Louis,
The audio circuitry is located in the main board. Try unplugging the TV for a while and try again if the audio comes back.
I would suggest to check all your settings in the audio section first and if everything seems OK then the main board should be replaced.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
I have had the same issue with a Westinghouse 50 inch LED TV. I believe it is not the power supply but the HDMI input. You can temporarily work around by plugging your primary source into the other HDMI. You may also get some relief by using the Westy remote, finding the TV menu, then selecting (Option) (Restore All). There may be an arcane procedure to reset the HDMI.
tried to get with reset, if can not resolved do this. hooked up with a power PC speaker at the audio out jack. then turn on the tv unit as well as the powered pc speaker and make some volume adjustment. if you can get sound there the cause will be the sound amplifier circuit ( amplifier ic ). if you can not get sound there the problem will be in the sound processor at the main board.
as you present. that maybe speaker wiring or speaker have problem. if no . that"be main board not function good . need to replace as posible. good luck!
This TV comes with a remote that connects to the TV via Bluetooth. It
remembers which equipment is connected to the various inputs, and
automatically changes the controls to match the input equipment - really
nice! I found that it will control all my equipment, and since it
works via bluetooth, you don't have to have direct line-of-sight to the
TV. Wish that the bluetooth part worked for my satellite equipement too!
Programmable remotes will operate this TV, but depending on how old
they are, they may not be able to hit all the features of the tv - our
older directv remotes will operate the basic features, but only the
newer models will change the input source - so you may want to use the
remote that came with the TV. We have smaller kids, and wanted to limit
their use of the tv remote, because it has a slide-out keyboard similar
to those on some cell phones to make posting to facebook (one of the
apps that comes on the tv) easy. Since our youngest is 5, we thought it
might be best to keep that remote out of harm's way.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
