Machine makes noise but does not agitate - Washing Machines
  • 11,896 Answers
It is possible the motor is fried out, the bearings have seized, or belt fell off..
Posted on Jul 22, 2009
Whirlpool cabrio makes clicking noise when agitator or wash plate changes directions. On makes noise on agitate.
It is a machine moving parts will make noise actuator shift will make a click and when washing you will have a wining noise
that is normal full loads will be quieter
Dec 02, 2016 | Whirlpool Washing Machines
Why does agitator make a kinda grinding noise and machine will not spin?
some foreign object jammed under the agitator ???
unplug machine and use coat hanger to fish it out from underneath
Jan 19, 2016 | Washing Machines
I have a Kenmore wash model #110.200220 and it makes a noise when it agitates only
it could be the noise of clothes bottons or zip. Generally it's normal for a washing machine to make noise when agitating
Jun 15, 2014 | Kenmore Washing Machines
Washer does not agitate or spin. makes loud noise when it's on:filling, trying to agitate or spin and emptying.
Possible that the INLET valve is also making noise due to faulty coil, check , confirm by disconnecting the valve.
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 24, 2013 | Washing Machines
Whirlpool ult care II (plus) washer, agitator makes noise
yes, sounds like your agitator dogs are broken, four beige teeth inside top of agitator part only roughly 4.99 to 29.99 and labor 65.00 - 95 labor depending were u live and who u use. thank you
allbrandsappliancerepair.com
Sep 23, 2009 | Whirlpool Washing Machines
My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Oct 26, 2008 | Washing Machines
Terrible noise while agitating
THAT COULD BE A BROKEN or LOOSE SCREW THAT HOLDS THE INNER TUB in the Center mast, hope this helps AJ
Oct 25, 2007 | GE WHRE5260E Top Load Washer
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
