Question about Pasquini Moka Coffee Grinder
My grinder is jamming
I unscrewed the top burr and cleaned it out the best I could. Could I be placing the bean bin on top incorrectly? When I hit rocker switch the burr turns just for an instant, then jams again. Can you advise on this?
  • cshields Dec 04, 2007
    I found the solution myself which turned out to be the output opening for the grind was jammed tight. Thankfully an ease solution. Cindy
  • 833 Answers
Possible that you installed something incorrectly but I don't think so. It sounds like you're not after the right problem. My guess would be that some bean shards got into the motor or some other place. Most of the motors used on these machines are geared down so that they make more torque and lower speed. Thus...the motor itself is actually quite weak. That's why it is jamming.
What I would start with: take the unit apart as much as you can...by taking out the burr, the receiver cup and all that. Turn the unit over and tap it onto a newspaper covered table with some bit of force. Do it a couple of times. That may fix it. If not, you'll have to disassemble it and find the item jamming it up. Be sure the unit is unplugged when handling it. It is possible that some of the screws are non-tamper. You can get the right bits at the hardware store. Be sure to tighten all screws when you're done.
Posted on Dec 03, 2007
How do I clean the inside of the coffee grinder kitchenaid model A-9
Instructions Things you need
  • Soapy water
  • Screwdriver
  • Burr cleaning brush
  • Damp cloth
1 Turn off your KitchenAid coffee grinder and unplug it from the socket.
This reduces the risk of injury while cleaning the appliance.
2 Turn the bean hopper, located at the top of the grinder, counter- clockwise and remove it from the appliance.
3 Slide the coffee bin toward you to remove it from the grinder.
4 Wash the hopper, hopper lid and the coffee bin in hot, soapy water. Rinse and dry these parts after cleaning.
5 Locate the grind control dial on the front of your KitchenAid coffee grinder. Screws are located to the left and right of this dial.
6 Turn the screws counter-clockwise with a flat head screwdriver to remove them from the grinder.
7 Pull the entire faceplate assembly gently toward you and out of the KitchenAid coffee grinder. The faceplate assembly is attached to the back of the grind control knob.
8 Pull out the burr shaft assembly, which is right behind the faceplate assembly.
9 Brush the burr shaft assembly with the burr-cleaning brush included with your KitchenAid coffee grinder to remove any debris or remaining grinds.
10 Reassemble the KitchenAid coffee grinder by returning the burr shaft assembly and faceplate assembly to the appliance. Tighten the screws with a screwdriver to hold the assemblies in place.
11 Wipe down the exterior of the coffee grinder with a damp cloth.
12 Return the clean coffee bin, hopper and hopper lid to your clean KitchenAid coffee grinder.
Aug 17, 2012 | KitchenAid Model A-9 Coffee Mill Grinder
Tip
Saeco Italia automatic espresso coffee machine Grinder Cleaning Instructions
Saeco Italia Grinder Cleaning Instructions
Removal
Step-1: Remove beans that are in the bean hopper without spilling them inside. (Use Vacuum).
Step-2: Remove the beans container by removing 3 phillips head screws. Remove the rubber gasket from below the hopper. At this stage the upper burr will be visible.
Step-3: Rotate counter-clockwise the outer ring of the grinder assembly (the ring has gears half way around), until the red mark is at the 9 o’clock position, looking at it from the front of the machine.
Step-4: Lift the upper burr by using the fins that are on top. Press lightly on the doser adjustment gear, to clear it from the dose adjustment gear.
Cleaning-
At this stage, the grinding chamber will be exposed. Clean out any crushed coffee in the grinder chamber and the burrs. Use Vacuum and cleaning brush.
To Re-Assemble
Step-1: With the red mark on the outer ring still at the 9 o’clock position, replace the upper burr back into the grinder. Make sure that the red line (on the upper burr) is at the 3 o’clock position. This position will align the other tabs as well. During re-installation, press slightly on the doser adjustment gear so the upper burr will clear it as it is placed back in.
Step-2: With the Upper burr in place, rotate the outer ring clockwise until it stops. The two red marks should be aligned at the 3 o’clock position underneath the doser adjustment gear.
Step-3: Replace the soft rubber gasket back on the upper burr. Use the fins to align it properly.
Step-4: Slide the doser adjustment gear toward the front of the machine until it stops.
Step-5: Before replacing the bean hopper, rotate the grinder adjustment wheel to Zero (0), and the doser adjustment wheel to Minus symbol (-). Place the bean hopper into position on the machine, slightly adjusting each adjustment wheel as you are placing it down in the machine. Once in place, fasten the bean container with the 3 screws. Test each adjustment wheel through the full range of motion. The grinder knob rotates from 0 to 18 and back, and doser knob from Minus (-) to Plus (+) and back.
Now position the grinder adjustment knob at Eight (8) and the doser adjustment knob to the halfway point between the Plus (+) and the Minus (-) marks. This will put the machine back to the factory setting.
When using for the first time after adjusting the grinder, it may take more than one grinding cycles to make the first cup of coffee.
on Aug 12, 2010 | Coffee Makers & Espresso Machines
Beans do not feed anymore. I have to shake the grinder to get them to feed.
- it is happening from time to time at all brands, you need to:
  1. remove upper burr holder
  2. unscrew lower burr holder bolt
  3. go with bolt in some metal workshop and ask for one peace of drill above bolt to be attached
  4. explain the way of rotation of burrs to metal workshop master so he wont mistake to do the drill in opposite way
  5. come with drill attached bolt at home , clean good the grinder, assemble the drill attached bolt.
  6. assemble upper holder and the plastic bean container (inspect does the drill touch the tongue for closing the beans at bean container)
Feb 12, 2011 | La Pavoni Coffee Makers & Espresso...
Hmm, I have Capresso Infinity Burr Grinder #560, and I accidentally placed the upper burr back in upside down. Now it is stuck. I do not see the "black section with a long slot" around the blade.
Yes! I had the same issue with putting the burr in upside down and then twisting it an effectively "locking" it in there incorrectly. I tried the "knife" solution that worked for some people here, but it was placing the bean container back on and twisting counter clockwise that did the trick!
So glad I found this thread and didn't give up trying to fix my burr grinder (which we love).
Thanks to jaybayca!
Jan 08, 2011 | Jura Capresso 560 Electric Burr Grinder
I keep getting "Fill Coffee Bin" when the bin is
Sounds like the grinder is blocked. Set the grinder to the coarsest setting (largest number) and try a few more times. If still no luck then vacuum out all the beans, run the grinder again a couple of times and then add a small amount of fresh beans (not from a fridge or freezer as these will be moist and can cause problems) and try making coffee again. If after a few tries it still doesn't work then you will either have to remove the top grinder burr and clean both burrs (not recommended unless you are bit of a handy person) or you could try vacuuming out the beans again and letting the grinder dry out for a while (although unlikely, it could be wet from water spillage). Good luck hope this helps.
Dec 14, 2010 | DeLonghi EAM3400 Espresso Machine
Cuisinart coffee grinder keeps clogging
Unplug first. Unscrew the top. You need a long thin screw driver Phillips head is the best. Pock around the exit and entrance where the coffee beans are ground. Remember, the better the coffee and you will get more clumping of the beans. I works great. It is pain. The Chicago Clout man exits.
Feb 06, 2010 | Cuisinart Supreme Grind DBM-8 Electric...
My cuisinart burr coffee grinder will not turn on
This model sometime gets plugged up with grounds.
Unplug the grinder, and remove the bin where the grounds go. Look inside the grinder part where the grounds come from the grinder into the bin. This should be clear, and you should be able to see part of the grinder wheel inside. If this is plugged up with grounds, then you'll want to clean it out, but it's possible that the motor has already burned out (we killed two of them last year at my office this way)
Pour out any whole beans that are in the top part. You can pour them in a bowl to save them, you don't have to throw them away.
Unscrew the top part until it detaches from the grinder. This will take 20 or more rotations -- just keep turning it counter-clockwise.
You'll want to do this next part over a sink or a counter that's easy to clean -- you're going to dump a lot of ground coffee.
Looking into the grinder from the top, you'll see the grinding wheel in the center, and packed coffee grounds around the edges. Use a plastic knife or bamboo skewer to clean out the ground coffee. Don't use a screwdriver, metal silverware, or anything metal, as this can damage the grinder housing. You also want to clean from the bin opening. When you're done cleaning, the grinder wheel should turn freely.
Reattach the top portion, put the bin back in place, and turn the grinder on. It should turn on and spin the grinder wheel. If it still doesn't, then your motor is burned out. :(
If it does turn, then put the coffee beans back in and enjoy a cup -o- joe!
Jan 30, 2010 | Cuisinart (CCCCUISINART) Grinder
Oily beans seem to have clogged our coffee grinder up. What can we do?
Rotate the bean hopper counter clockwise until it stops. Lift it off. Remove the outer burr with the 2 wings and clean under the burr. Clean the opening going to the chute for ground coffee(inside where the burr was).
Install the outer burr. Install the bean hopper. Rotate the bean hopper to the French press grind (coarsest) and operate the grinder. This will clean the burrs and the passages. If it starts to clog, repeat the last part to clean the burrs and passage. It must be grinding to go to a finer setting, but you can go to a coarser setting any time. Another thing. Turn the grinder upside down (empty) and rotate the bean hopper back and forth to clean the threads of the adjusting burr..
Dec 20, 2009 | Solis Maestro Electric Burr Grinder
Krups GVX2-12 Electric Burr... Problem:
First, unlock and unscrew the upper burr carrier. Clean and check the upper burr by gently running your finger over the teeth in the cutting direction. It shoild feel moderately sharp. If it feels very blunt, look at the teeth under a good light. If you see a substantial "flat spot" at the top of the teeth, probably the burr set will need replacement.
For the bottom burr, clean carefully its teeth, and the entire area in which it is housed. Include the outlet orofice as well. You may find a lot of oily deposits within here, so just clean them off as best as possible.
When all is clean, insert the top burr holder back in place. Screw it down until both burrs touch, then back it off (say) 1/4 turn, and lock.
Put some beans in the top, and switch on. Adjust the top burr until the desired grind is obtained.
The ground coffee should feel like a coarse sand when close to the desired grind size.
Mar 13, 2008 | Krups GVX2-12 Electric Burr Grinder
Won't come on?
I just bought a brand new unit and as recommended I unscrewed the top bean hopper and the coffee ground container-cleaned and wiped.After that I screwed back everything and tried to grind some beans.The timer was ticking away but the grinder just refused to start.I switched off the main and unscrewed the hopper and carefully screwed it back.Halfway through,I noticed and felt that you must balanced and screwed it with a smooth movement until the the whole piece is in place.The grinder just started without a hitch.This grinder has a protection circuit whereby if any part is not properly installed it will not start.
Mar 07, 2008 | DeLonghi Retro DCG59 Electric Burr Grinder
Coffee Makers & Espresso Machines Logo
132 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
