Question about Samsung TX-R3080WH 30" TV
My tv txs3082 blink constantli
My tv samsung txs3082whx/xaa blinkinc constantle (wath can i do
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
Posted on Jul 22, 2009
Samsung txr3079whx/xaa 5 blinking lights
5 blinks to Samsung indicates a fault in the main power supply output voltage.
Jan 23, 2013 | Samsung Televison & Video
Samsung TXS3082WHX/XAA
The relay cuts inside the TV after swich on. Should be some short circuited component/board inside it. Check and replace it. The click sound you hear is of the clicking of the relay. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Nov 29, 2012 | Samsung Televison & Video
Model Number HLT5676SX/XAA 56" Samsung
your question does not help us or you as we do not know your problem .
Jun 09, 2017 | Samsung DLP HL-P5663W 56" TV
I have a HDTV Samsung TV, Model #TXS3082WHX/XAA and I would to connect my desktop to the TV. Do you know what cables are needed?
Look for a monitor cable with 15 pin RGB plugs on each end, that will transmit the video portion of the signal so you will need an audio cable with 3.5mm plug on each end also, there are RGB cables that have the audio cable together as one big cable.
Good Luck !
Feb 09, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Samsung HLS4266WX/XAA warnings w/ new lamp also
You may be in need a new ballast, the assembly that excites the bulb into producing output.
Sep 20, 2017 | Samsung Televison & Video
SAMSUNG TXS3082WHX/XAA Won't Turn On
All of these tv's are board replacement only the individual parts are not available. The boards can cost anywhere form $200 - $400 each. Even if you do it yourself it is still an expense, if you get the blink code i can point you to the correct board. These sets have different boards even within the same model range. One of the first diagnostics is does the back light come on, if not then you either have a balancer error or a bad bulb in the panel. Why i suggest this is because it is the most common problem. If it is the bulb in the panel you have to replace the whole panel, the bulbs are not available as an individual part.
Sep 02, 2009 | Samsung TX-R3080WH 30" TV
Training Manual for HLN617W1X/XAA
Try Googling (Samsung)(HLN617W1X/XAA)(manual) without parens. For a service manual, you may have to contact Samsung directly.
Nov 07, 2017 | Samsung HLN617W 61" Rear Projection HDTV
Samsung TX-R3080WH 30" TV Logo
492 people viewed this question
Henry  Thomas
Henry Thomas
