Question about Kodak EASYSHARE Z1285 Digital Camera
Kodak 1285 will not stay on
Camera shuts off when turned on ,I have tried new batteries ,no luck
    President:
  • 2,761 Answers
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
Kodak Z 1285 shut down while transferring pics - Won't start up.
you can look on the kodak home page if exist a new update to resolve this problem. but i am very sorry for you why this is a not good signal. its probably that the camera have a processor problem and dont read no more the cards. prove to first to change the card type. and look that the card have not a hold bloc system. this is the first prove change the card look if kodak have updates for this problem of the hompage of your specific model. and good luck
Jun 01, 2010 | Kodak EASYSHARE Z1285 Digital Camera
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
____________________________________
Kodak EasyShare Z740 Manual Download
on May 01, 2010 | Cameras
Tip
I hope that helps.
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
Staying on and blurriness
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. Please also try to upload new firmware: Connect the camera with the computer. Turn the camera on. Click onto the link and follow the instructions. http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=11033/11261&product=EKN032924 If you're still experiencing problems. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 18, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Kodak easyshare m340 turn on lens come out then shuts off
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Put new batteries in but there still is no power
Check if your using the recomended batteries for this camera Easyshare C613. The batteries are 2AA Ni-MH batteries, 2 AA Lithium batteries or 2 AA Alkaline batteries. If your use this kind of batteries and they are new out from the box try this steps.
1. Remove the memory card and the battery on the camera
2. Clean the both battery contacts with clean dry cloth
3. Put the battery back in the camera in correctly
4. Set the camera in Auto "it's the camera icon on the dial of the camera."
5. Turn it on
*If it turns ON take photos and review them check if it will stay on
*If it doesn't turn ON or stay ON contact Kodak support line @ 1-800-235-6325 (23KODAK). You can also try to log on to www.kodak.com/go/stepbystep.
Nov 16, 2009 | Kodak EasyShare C613 Digital Camera
Kodak M1033 shuts off
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
Aug 03, 2009 | Kodak EasyShare M1033 Digital Camera
Camera shuts off like dead a dead battery with new ones
Aug 02, 2009 | Kodak EasyShare C340 Digital Camera
Kodak CX7430 can only take 10 pictures with a new battery
Chances are that the problem is corroded battery contacts inside the camera. Remove the batteries and clean the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue that's in the camera from the cleaning, then reinstall your batteries. Hopefully this will cure the problem and get the camera back up and working the way it should.
If that doesn't do the trick, you might want to try your luck with the Kodak Troubleshooting guide at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10&pq-locale=en_US
Mar 08, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE Z1285 Digital Camera Logo
305 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
