Question about HP Jetdirect 615n Print Server
Trouble with wireless connection JetDirect ew2400 on Dlink DIR855
I can't connect my ew2400 to my Dlink wireless router via wireless. Ok with cable.
I use the latest firmware on both my units.
I found that the EW2400 Jetdirect will not work UNLESS you use WEP security. I have tried several times setting up using the WPA, but with no luck. Once I changed my wireless router to WEP and configured the EW2400 with the WEP settings, it worked with no issues - hope this helps
Posted on Aug 06, 2011
Hi i Just bought dlink 600 i am using compaq and has iphone and internet tv all of them cant connect by wifi my compaq can only connect with a cable. on my tv it says internet connection failed. and btw cm...
ok first prep. we need to configure your router. to do that we need your compaq laptop directly connected to the dlink via ethernet cable. after securing the connection, try to open a browser, whether internet explorer or mozilla firefox. go to the address bar and type in, 192.168.1.1 it would ask you now for a username. username is " admin " password is " password " if it wont let you in, try "admin" for password. if it still cant, try to live it blank and just click on login. it would take you now to the dlink router page. there you can configure your wireless connection and set your network name. make sure to click apply settings after configuring it. then try to check your wireless connectivity again. this should work.
Sep 02, 2011 | D-Link DIR-600 Router
How do I connect a Dlink wireless router to a Netgear WiFi Internet adaptor?
Hi there is two way to connect best is to connect via cable ,DIR 615 login to router setting by typing 192.168.0.1 enter user name and password uaser name will be admin and password could be admin or blank or you need to enter text " read the manual to access the router via internet explorer" make sure WAN connection is DHCP connect LAN cable from your main router to the WAN port of your Dlink it should be ready in 1 miutes also if it support WDS you do not cable it can find the main router signal and connect to it and boost it , should you need any help please post me your question to http://computernetworksupportindubai.com/
Jul 22, 2011 | D-Link DIR-615 Wireless Router
After moving to a new house/ new state, I can not get my HP 2035n to connect wirelessly to the router. It will print from any of our computers, but must stay connected to the router. I can find no...
The HP P2035N doesn't have a built-in wireless ethernet connection. It has a wired ethernet port. To connect to a wireless router, you need the HP Jetdirect ew2400 802.11g Wireless Print Server or the HP Wireless Printing Upgrade Kit or a similar device (note: not all third-party wireless print servers will work with the HP printer). Did you have something like this and misplace it during your move? If you did, try to find the print server to use the wireless option. Otherwise, continue wired ethernet option since it is working.
HP support for the printer (manuals, set up infomation, and drivers) is available here: http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3662025&lang=en&cc=us .
I hope this helps.
(HP models with a W at the end of the model number have wireless capabilities without any additional hardware.)
Apr 30, 2011 | HP P2035N LaserJet Monochrome Printer
I have a d link d1 514 router. I'm unable to open 192.168.0.1. if i put the internet connection wire in LAN then I'm able to get internet access using cable but if i put the wire in wan, I'm not getting...
carry out the resetting of the dlink router
then use lan cable to gain access to dlink router,
set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
if it has a built in wizard then just follow the on screen instructions
you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
and the your done. disconnect the laptop from wired connection and connect via wireless
Oct 16, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Can connect to DLINK adsl2 router via wirless but
Make sure your LAN connection is not disabled,
make sure that you are getting a valid IP address form the router
If you need commands for this let me know, also which OS are you using
Jan 31, 2010 | D-Link DI 514 Wireless Router (DI-514)
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
CISCO 2800 router interface stop responding
What kind of cable do you have connected from the DLINK to the Router? Is it an ethernet cable 3,5e,6?
Sep 13, 2007 | 3Com OfficeConnect (3CRWE454G75)...
HP Jetdirect 615n Print Server Logo
419 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
