2003 Mitsubishi Galant Logo
Posted on Jul 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace driver door check in MItsubishi
How to replace the driver "door check" part in MItsubishi Galant 2003 ?
Anonymous
Level 2:
  • Expert 74 Answers
  • Posted on Aug 31, 2009
Anonymous
Expert
Level 2:
Answers
74
Questions
0
Helped
36931
Points
160
Take a hammer and remove pin at the body pillar,remove the two 10mm bolts on the door check(keeper} -pull door check out,install new keeper, pull out keeper arm and guide into pillar slot ,reinstall pin
Where on the web can we find a detailed fuse box diagram?
Here!
Fuse box diagram Mitsubishi Galant
fusesdiagram.com > mitsubishi > fuses-and-relay-mitsu...
Fuses and relay Mitsubishi Galant 1997-2004. For the Mitsubishi Galant (EA) 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004 model year. Fuse box in passenger ...
Fuse Box Mitsubishi Galant 2000 - Wiring Diagram
cars-trucks24.blogspot.com > 2018/02 > fuse-box-mits...
Feb. 1, 2018 - How to replace fuel pump 2000 2005 mitsubishi eclipse. For the mitsubishi galant ea 1997 1998 1999 2000 2001 2002 2003 2004 model year.
The Galant Center
www.thegalantcenter.org > showthread > 51323-Questi...
tamim13 said: 07-04-2012 02:41 PM ... 2nd picture is my fuse box (under the hood - taken from the drivers side facing the fuse box) ... I need to check my owners manual to see if the fuse diagram has an explanation of the relays as well.
Why is no fuel getting to the injectors?
Check the Fuel pump
2003 Mitsubishi Galant Repair and Maintenance - RepairPal
repairpal.com > Cars > Mitsubishi > Galant
Information on the 2003 Mitsubishi Galant, including known problems, recalls, user ...2002 Mitsubishi Galant ... it will crank but not start not getting any spark or fuel what can you suggest. would like . ... The fuel return line fitting at the fuel pump may be restricted, causing excessive fuel pressure in the fuel injection system.
2answers
Car is dead,won't hold charge,now lights are flickering and there's a ticking noise inside the car
2003 Mitsubishi Galant Problems - RepairPal
repairpal.com > Problems > Mitsubishi > Galant
Problem with your 2003 Mitsubishi Galant? Search our list of user submitted and RepairPal verified problems and issues.
Mitsubishi Galant Alarm Problem
A part inside the door known as the "Door Ajar" sensor switch is defective, replace it. It is attached to the door latch in most makes
Where is the fuses located in a Mitsubishi galant 2003
There is one located inside the vehicle on the drivers side and then the main one is located under the hood in the upper left hand driver side area. Hope that helps!
1helpful
2helpful
2000 mitsubishi galant and all four of my windows will not rolle
check fuses first check power at master switch drivers door see if windows work from passenger switchs may need a master switch
5helpful
2answers
Replacing speakers in Mitsubishi Galant
If the car is an 03 galant it is very simple to remove.
DRIVER SIDE:
Remove the window crank if it is not Electric Window.
Remove the Screw that holds the "Open Door Handle" cover.
Remove the Screw that holds the "Pull Handle Pocket"
Remove both plastic covers.
Remove all 3 hidden crews that have a plastic cover over them.
One is toward the front of the door top and the other two are toward the rear of the door top and bottom side.
Carefully pry around the door trim panel to disengage it from th retaining clips, along the sides and bottom. If you have electric windows, disconnect the if from the door trim to access the speaker. Same procedure for both doors.
Driver door unable to lock or open using the remote - 2002 Galant
If you can unlock it with the key,and not the remote, then it sounds like the lock actuator is not working in that door.In order to check it, the door panel has to come off.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
