Question about IBM Office Equipment & Supplies
How do you install the correction tape? Any instructions.
  • IBM Master
  • 3,594 Answers
Is it a Wheelwriter or a selectric?
DickyO
Posted on Aug 18, 2009
  • Dick O Reilly Sep 08, 2009
    Go to lexmark.com, click your way to publications you can download a manual with pictures
    DickyO
INSTALLING CORRECTION TAPE ON A BROTHER SX4000 TYPEWRITER
try to see it in the sides or it might be in the bottom of the machine in some models remove the older and replace the newer.
Aug 25, 2008 | Brother SX-4000 Typewriter
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
How to install easystrike lift-off tape on Lexmark wheelwriter 1000 typewriter IBM part no. 1337765
It is installed on the bottom of the ribbon it self. instructions will come with new correction tape. Hope this helps
Aug 17, 2010 | Office Equipment & Supplies
Instructions for installing ribbon on wheelwriter 5/w correction tape
The correction tape clips to the bottom of the ribbon, The ribbon has two small feet that hook into the front of the ribbon deck then just snap it into place the blue latch holds it in place.
A manual is available at LEXMARK>COM click on support.
DickyO
Jun 23, 2010 | IBM Office Equipment & Supplies
Replacement of correction tape
The correction tape cartridge "piggybacks" under the ribbon cartridge. Flip your black ribbon over, line up the front dges of the two ribbons and gently press down on the correction ribbon 'till the two wing tabs at the top are attached to the slots at the top of the black ribbon. Be sure to take up any slack in the ribbons BEFORE re- installing.
GL
Jul 06, 2009 | Lexmark Wheelwriter 15 Series II...
How to install correction tape and what one to buy?
Where can I locate instruction on how to install the correction ribbon on a Smith Corona electric typewriter?
Jun 04, 2009 | Smith Corona Wordsmith 100 Typewriter
The correction tape isn't working. it's installed properly, i think, but it doesn't erase anything.
Try taking the tape out and re-installing with the "dull" side towards the paper...if that doesn't work try a new correction tape.
May 29, 2009 | Olympia Mastertype 3 Typewriter
Correction Tape
The correction tape which should be a yellow spool and the correction ribbon cartridge should be a yellow also, sometimes orange, first. The correction tape has to in front of the black correction ribbon. in othe words this is the order. Platen, paper, correction tape, correctable film ribbon, printwheel. Also make sure correction tape is dull side toward paper. Shinny side should face operator...
Aug 12, 2008 | Brother ML-100 Typewriter
I have a brother SX4000 at work and I am having a hard time getting the correction tape on. Can you help with any instructions?
Jan 29, 2008 | Brother SX-4000 Typewriter
66 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
