Question about Samsung Televison & Video
Samsung HLP4663W needs fan replaced.
I believe my HLP4663W needs to have the large (3.5'') cooling fan replaced. It is the one that is basically behind the lamp holder. I took the long, lower back panel off the tv set, but it seems to be hidden behind a circuit board on the right side, and also ''encased'' in some sort of frame which looks like I will have to access it from ABOVE, as well as from the side. Every article I have read so far immediately discounts the fans and goes right to the color wheel. I just want to know how to replace that fan behind the lamp. If it keeps making the noise after that, I will then go after the color wheel (which I've already purchased). Any help with THE FAN replacement will be GREATLY appreciated. Thank you very, very much.
Apparently I was in denial about the color wheel. With my son's help, I pretty much confirmed that it was NOT the fan. I could have replaced the fan after pulling the boards out to do the color wheel, but didn't want to shoot myself in the foot. I had my son hold the lamp saftey switch so we could turn the set on with the lamp access panel off. Then after the buzzing started, I VERY, VERY carefully reached in & touched each of the 2 fans to see if the pitch of buzzing changed, or if the fans were vibrating at the same frequency as the buzzing noise. It did not change one iota. So I went with an educated assumption that it was in fact the color wheel (just like all the posts in the threads had said). Our set was born in 10/04, and the color wheel was much easier to do than the one in the excellent step by step post that I found elsewhere. The procedure for accessing the fan (if the need be) is basically the same as the colorwheel replacement procedure, as far as removing panels & boards, etc, and gaining access to the fan (you can't do it just thru the lamp access panel). It took me & my son about 2 hrs (including the fact that we forgot to reinstall the colorwheel hood/shroud the first time we reassembled). We also didn't have that jumper to deal with either. HOWEVER, while the picture looks great for the most part, I think I may have to use the service menu to set the color levels correctly. The problem being with the black levels I think, because in a dark scene in a movie, shadows look blotchy, almost rainbowy in a somewhat pixelated sort of way. The new colorwheel came with a little sticker with the new CCA color setting values as well, but in researching the service menu access codes, I read one post where someone said that simply accessing the service menu (even if it's just to see how many hours you have on your lamp, without even changing any settings), will reset all your settings. I don't know if this is a problem for me, as I never changed the settings before, and never had it serviced by anyone else.
Posted on Jul 24, 2009
Can you replace a fan in the samsung DLPTV model #hln437wx/xaa
it has 2 or 3 fans---they rarely fail but can cause issues---Are you hearing a high pitched whine or fan like sound? I KNOW WHAT THAT IS IN THIS SET...
Apr 09, 2012 | Samsung HLP4663W 46" Rear Projection HDTV
At start up TV makes siren & ratching like sounds, no picture screen dark, requires turning TV off, is this cooling fan or color wheel problem & lamp replacement or all
That could be any of them. If you can get access to an analog meter such as voltmeter, you can test power to the cooling fan, to the color wheel, and to the lamp. See if any or none are getting power.
Aug 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Need to replace cooling fan
could the reason for the picture going off after 10 mins be the cooling fan if so how do i replace it my model is sp46l6hx
Oct 23, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Error message to check fan #3. Where is it?
If you take the rear of the set off and hold the Interlock Switch on the right side up,Turn "ON" the set and look for three fans,one of them will not be turning. There are two small fans and one large one. The Large Fan is the Lamp cooling fan and the two fans are for cooling the Ballast and the other one is for cooling the DMD chip Heat Sink. The two smaller fans are the same type. The Lamp Fan (Large one) part# is BP31-00024A and the two small fan #s are BP31-00001A. They are all easy to replace.
Jul 13, 2009 | Samsung HLN467W 46" Rear Projection HDTV
Whizzing noise
Need to check both of them.
-- open the back cover & unplugged two socket for cooling fan.
If still noise there, need to exchange the color wheel.
Jan 25, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
TV keeps turning off after a few minutes.
when all three lights are blinking its indicating that the lamp may be defective.
Sep 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Sporadic Hum on HLP4663W
I would guess that its the fan for the lamp, as the color wheel will power down as soon as the power is cut. the cooling fans will continue to run
Jun 12, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
281 people viewed this question
Henry  Thomas
Henry Thomas
