Question about Bunn VPR Coffee Maker
Bunn coffeemaker steaming and bubbling over when OFF
Twice this week our office coffee maker has started steaming and bubbling and spraying water out while turned off.
I've poured in a pitcher of water into the tank which stops the steaming and bubbling. The water sprays out into the pot and then everything is fine again. (This has also happened a few times randomly in the past.) This coffee maker is at LEAST 12 years old - probably older - because it was here when I started working here.
What would cause this and is there a solution or do we need a new pot?
Thanks!
You need to replace the thermostat and the hi limit switch punch up bunnomatic.com and get partsthis machine is good for many years
Posted on Jul 23, 2009
    President:
  • 635 Answers
And dont forget to clean it out with white vinegar while you have the chance, Twelve years is a lot of buildup.
Posted on Mar 13, 2010
Our Bunn VPR coffeemaker takes a LONG time to heat up the water. If we don't wait several hours between pots of coffee, the coffee is luke-warm at best. Does this sound like a heating element or...
We left vinegar in the coffeemaker overnight. Seems to have done the trick - water is heating up now after 20 or so minutes instead of several hours.
Jan 05, 2010 | Bunn VPR Coffee Maker
Bunn coffeemaker starts before water completely in reservoir
You might try this first. Remove the entire top lid and remove the clear suction cup located near the back of the brewer. Clean this cup with white vinegar and also take your deliming tool and place it in the hole where the suction cup was and clean out. If this does not correct the problem, please call customer service with the model and code date. If your machine is 3 years old or less, we can replace it at no cost. If it is over 3 years old, we will replace it at a reduced price.
Oct 06, 2009 | Bunn NHB Coffee Maker
Sparking and spraying water out back
Remove the top panel, and then the pan like basin(big nut in middle, Make sure you keep gasket under basin in good condition. That should give you a starting point for your repair.
Sep 28, 2009 | Bunn VP17-3 Coffee Maker
We find water under the coffeemaker in the morning.
Sounds like a leaking water pipe from the water source, unless you have a over temp heater and this results in steam and dripping.
Mar 30, 2009 | Bunn VPR Coffee Maker
BUNN VPR Overheating
Thermostat is either bad or your heating element is bad. Check both and also check for calcium and lime build up
Feb 20, 2009 | Bunn VPR Coffee Maker
Bad tasting coffee
you can always clean a coffeemaker with vinegar, but always pour in cold, so you can do it twice or more, but dont re-use the stuff you just used, wait till it's cold or just use some other.after use clean by let water through 2 or 3 times, (also only cold water)
Jan 28, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Getting to hot
The thermostat or tank heater is not working properly. Please get the model and date code located on the bottom of the machine and contact customer service. If your machine is 3 years old or less, it will be replaced free of charge. If you machine is over 3 years old, it will be replaced at a reduced price.
Jan 17, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn coffeemaker
If you still have warranty on the machine take it in to the nearest service center.
Its probably a lose pipe in the machine. so if you dont have warranty left just open it up and look for lose pipes and reconnect them.
Jul 14, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Bunn Coffeemaker CWTF35-4
Hook it up to cold water. It has a heating element in the tank that heats the water.
Oct 24, 2007 | Bunn RL Coffee Maker
My bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Sep 15, 2007 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn VPR Coffee Maker Logo
400 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
